snippy
| posted on 28/4/13 at 09:32 PM |
wooden floor - what paint?
Any ideas what is the best thing to use to paint the underside (roadside) of a wooden floor based kit? It`s probably marine ply.
tegwin
| posted on 28/4/13 at 10:09 PM |
I would consider sealing it with a sealant used for concrete ponds (available from most aquatic stores) and then a couple of coats of a decent
polyester top coat
Or just use an exterior grade paint from DIY store if you are feeling locost
[Edited on 28/4/13 by tegwin]
www.verticalhorizonsmedia.tv
stevebubs
| posted on 28/4/13 at 11:14 PM |
Surely Yacht varnish??
snippy
| posted on 29/4/13 at 07:27 AM |
I want to paint it black to match under the chassis. One suggestion is a coat of resin to seal it first and then paint on top?
tegwin
| posted on 29/4/13 at 08:21 AM |
Resin is very brittle so not a good idea!
Poly top coat is slightly more flexible...
| posted on 29/4/13 at 10:15 AM |
I'd seal it first, then apply a coat of car body under seal. The black stuff that stays soft. That would help protect it from stone damage as
well.
| posted on 29/4/13 at 07:24 PM |
Underseal dries out and cracks if your going to use anything like that try some stonechip which dries out but stays flexible
