Author: Subject: Rivet size, what do I need to specify on order
andyace
posted on 18/5/05 at 08:17 PM Reply With Quote
I want to order 4.0mm alu/stainless rivets (see below for 4.8mm prices), however I want to be sure I order the correct size. 4.8 is obviously the hole size! I am assuming the x11 to be the body length (alu bit). Is this an ok length for fixing floor and panels to chassis. What is the grip length.
I am opting for 4.0mm rather than 4.8mm as I only want to order 1 size to cover all uses (Floor, tran tunnel, seat back etc.)
Hope someone can tell me as I want to get the floor on quickly.
4.8 x 11 sealed aluminium rivets - grip 4.5 - 6mm
Prices per 1000
Aluminium Body / Steel Mandrel £14.19
Aluminiumj Body/ Stainless Mandrel £44.00
All stainless steel £53.57
DaveFJ
posted on 18/5/05 at 09:56 PM Reply With Quote
the grip range seems very limited
are you sure that everything you want to rivet will be within this band ?
[Edited on 18/5/05 by DaveFJ]
Dave
andyace
posted on 19/5/05 at 07:43 AM Reply With Quote
No not really, that is why I am asking the question as to what does the grip range mean and also whether x11 is too long or not long enough.
Thanks, Andy
