cerbera
| posted on 21/1/06 at 03:07 PM |
Peugoet/Citroen wheels
Am I right in saying Peugoet/Citroen wheels are the same PCD as Ford? If so what else do I need apart from spacers, to fit them to my car?
Thanks.
Marcus
| posted on 21/1/06 at 03:21 PM |
Yes, they're the same PCD (108mm).
The spigot rings (centre holes) are a little bigger than Ford, but you can get inserts made.
I didn't bother, trusting the studs to carry the weight of a light car.
The offset is something to look at.
If you're replacing Escort wheels, you're ok (et15 - 18), Sierra ones are a different story (et38)
Marcus
Marcus
Because kits are for girls!!
piddy
| posted on 21/1/06 at 06:48 PM |
You may also find it hard to get the correct wheel nuts with the Peugoet taper.
Marcus
| posted on 23/1/06 at 09:21 PM |
Dunno about wheel nuts, mine had standard 60° taper.
Marcus
Marcus
NS Dev
| posted on 24/1/06 at 11:11 AM |
I'm using flat face sleeve nuts and drilling the wheel holes out slightly to 5/8"
