prelude1980
| posted on 21/5/07 at 06:18 PM |
Finishing Fibreglass
I've tried searching but i can't seem to find out what people do to finish the cut edges of fibreglass. I mean when you drill or cut a
hole what do you do to that edge to protect it?
| posted on 21/5/07 at 06:47 PM |
Put masking tape on the top surface of the gelcoat, drill or cut from the gelcoat side only (downward strokes only) then with a drilled hole use a
countersinking bit to ream the edges, with a cut edge use a file (downward strokes again from the gelcoat side only) to clean the edge....
Howlor
| posted on 21/5/07 at 06:56 PM |
I just got some paint mixed to match and touched up all the edges.
prelude1980
| posted on 21/5/07 at 06:58 PM |
would like a clear lacquer be any good?
hillbillyracer
| posted on 21/5/07 at 10:21 PM |
Would it not be best to seal the cut edge up with some fibreglass resin?
road warrior
| posted on 22/5/07 at 04:40 AM |
I always paint the inside of the bodywork satin black because it gives a nicer finish than patchy fiberglass colour and it is easy to wipe over with a
damp cloth. To finish off any holes or larger openings I run a deburring blade around the edge and then finish the edge with a black permanent marker.
It is a trick I learned from a cabinet maker. It is what they do on laminex edges. I have done this on my race cars for years and it always comes up a
treat.
The fiberglass shouldn't delaminate if it has been laid properly and it is already waterproof.
