Author: Subject: Bonnet Power Buldges.
mad4x4
posted on 22/5/07 at 11:57 AM Reply With Quote
I have just fitted new carbs and they foul the fiberglass bonnet. What is the best way to get a power buldge or two.
Could I heat up the Fiberglass and Strech and bend it - like bending plastic?
is there any aftermarket buldges that can be fitted that don't look Sh!t
Scot's do it better in Kilts.
flak monkey
posted on 22/5/07 at 11:59 AM Reply With Quote
GRP is made with epoxy resin which is a thermoset. You can heat it as much as you like, but it'll just burn, wont go soft.
Sera
http://www.motosera.com
stig mills
posted on 22/5/07 at 12:03 PM Reply With Quote
Once the GRP has curred its too late to reshape. It burns very well though so I would not heat it too much!
Scooby scoops are available but they only give you about 40mm
goodall
posted on 22/5/07 at 12:09 PM Reply With Quote
yep ill 3rd that you cant heat and shape grp because its made using resin, but doesnt have to be epoxy, i believe polyester resin is what is normally used with grp, epoxy is more commonly used with carbon but thats all by the by
if you wanted to do a real proper job of it you could try and make a mold of you current bonnet and then add the shape of the buldges to your mold and then make a totally new one but this could end uplooken even worse
Bluemoon
posted on 22/5/07 at 01:57 PM Reply With Quote
MK do one designed to fit, not bad looking.. only gives you hight, does not sick out the side..
Dan
[Edited on 22/5/07 by Bluemoon]
mad4x4
posted on 23/5/07 at 03:11 PM Reply With Quote
Problem is the gsxr carbs arre to high at the side. I can get the air fiters out the side no probs but the tops of the carbs are above the bonnet line
Where would I get resin and mattaing and dye for making my own?
