Author: Subject: making moulds
oadamo
posted on 12/9/07 at 10:06 PM Reply With Quote
making moulds
hi whats the best way to make moulds for body panels. i wasted a load of fiber so far trying to get it right.
adam
Alex B
posted on 12/9/07 at 10:17 PM Reply With Quote
What did you use and how? Foam blocks cut with a hotwire. Anything that will hold plasterto get a shape. Timber frames with wire mesh. Not done a lot but watched guys do it and thought . F**** that
Alex
Mark.
posted on 12/9/07 at 10:45 PM Reply With Quote
Tis a black art and no mistake but when you know how it's a doddle....just a tad messy.
Find someone local to do it for you as might be cheaper in the long run.
Mark
worX
posted on 12/9/07 at 10:47 PM Reply With Quote
Adam,
you could try reading this:
http://www.bayarearidersforum.com/forums/showthread.php?threadid=145975
It's a bloody long, but very good read, and will surely help you out!!!
stevebubs
posted on 12/9/07 at 10:54 PM Reply With Quote
Make yourself a buck out of plaster of paris, skim it with body filler, sand it to final shape.
Finally cover with 6 or 7 coats of release wax, then lay up gelcoat followed by matting to make a mould.
Simon
posted on 12/9/07 at 11:22 PM Reply With Quote
See this pic of mine (excuse the quality), should be all you need.
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=making%20panels.jpg
Basically, two sheets of MDF with slots cut in (with a jigsaw), to your desired profile.
Space apart at desired width, and insert a sheet of ally.
For the front arches, use plaster to form a nice contour on both outer edges, and on rears one side needs a nice outer contour, the other a square lip.
Grease or whatever you use for release, then gelcoat and layup.
Should take you a day to make all arches. I used this method on my scuttle too.
HTH
Simon
[Edited on 12/9/07 by Simon]
Alex B
posted on 13/9/07 at 09:58 AM Reply With Quote
Important to skim with body filler as Polyester resin don`t like water based filler materials.
Alex
Simon
posted on 14/9/07 at 07:25 PM Reply With Quote
Alex
I didn't and it worked fine, just make sure plaster is dry then apply release agent (which seals plaster anyway).
Simon
Alex B
posted on 14/9/07 at 07:41 PM Reply With Quote
Used Polyfilla on rear gaurd radius. Dried in house for a week till snowwhite. Pva plus four coats Simonize..............stuck and reacted to gelcoat
Alex
Simon
posted on 14/9/07 at 07:45 PM Reply With Quote
Nah, don't worry about PVA - you wouldn't put PVA in your bearings
Grease, man. Grease
Just don't leave too thick - and use a proper plaster, like Herculite, sets incredilbly hard.
Simon
Alex B
posted on 15/9/07 at 07:36 PM Reply With Quote
Grease?........I`ll try it.
Alex
oadamo
posted on 15/9/07 at 10:10 PM Reply With Quote
well ive spent about 4 days trying to mould carbon fiber around box section and trying to pull it off with no look. looks like iam gonna use steel. and ive given up on the panels lol.
adam
