wheezy
| posted on 19/9/08 at 07:44 AM |
2K paint touch up
Having just repaired a crack in my wheel arch after my off at Castle Combe I need to touch up the area. I have some 2 pack paint left from the
original paint job which I use without the hardner (so no isocynates) for touching up paint chips which does set after a few hours.
If I use a pencil airbrush to spray the paint over a 4 inch area without the hardner will it set?
Dave
iiyama
| posted on 19/9/08 at 07:46 AM |
If you dont use the hardener it shouldnt set at all!
If its broke, fix it. If it aint broke, take it apart and find out how it works!
westf27
| posted on 19/9/08 at 08:03 AM |
it does set up ok.When you dispense the paint from the pot the dribbles have no hardener,hard as bulletts
555
wheezy
| posted on 19/9/08 at 08:06 AM |
Ive used it with a pencil brush to touch up chips etc and it hardens of after about an hour and is completly dry after 24 hrs. I was just wondering if
it would go off if sprayed over a slightly larger area.
Dave
russbost
| posted on 19/9/08 at 08:58 AM |
Dave, it will go off but may take several days on a larger area, can be difficult to keep undamaged during that length of time & it might still
"fingerprint" for a month or more. Why not just pop a little hardener in with it, if you use a mask in a well ventilated area you're
not going to do yourself any damage - it's about as dangerous as smoking one cigarette I would think, but a lot less addictive!
