<<  1    2  >>
Author: Subject: Which Paint To Use With GRP & Ally
Nick Davison
posted on 24/9/03 at 01:13 PM Reply With Quote
Yuk. But I suppose it is ok to use if you don't get on with your neighbours!!!
So what is the problem with polyurethane, is it similar?
Nick
kingr
posted on 24/9/03 at 03:06 PM Reply With Quote
Spyder : True it contains cyanide, but then so did sweets many years ago, and writeable CDs have it in them, and old wallpaper. To paraphrase from this month's Car Mechanic's magazine, Sodium Chloride tastes great on chips, but Sodium Chlorate is one of the most powerful weed killers and does anything but taste great on chips. Just because it contains similar elements doesn't mean that it has similar properties.
Incidentally I'm not trying to play down the dangers of 2k, it's still not something to disrespect, just trying to get burst the myth that 2k paint "is like cyanide". You won't drop dead from a whiff of 2k, hell, you could probably do a whole car with a charcoal filter and not drop dead, but it would have severely and permanently affected you respiratory system, and who knows how much or little it would take to completely finish you off.
Kingr
posted on 24/9/03 at 03:49 PM Reply With Quote
It's the isocyanate component in the hardener that is carcinogenic according to the paint shop across the road. Cyanide is also a cumulative poison building up over the years till it reaches a level where it will affect the user.
yours, Pete.
Spyderman
posted on 24/9/03 at 07:24 PM Reply With Quote
Kingr
Agreed,
But everyones tolerances are different!
What might take several months of exposure to one person could seriously affect another after a few minutes exposure.
Is it worth taking the risk just to prove someone wrong?
I worked in an envirnment where you had to use the correct equipment or you didn't work. Health and Safety was taken very seriously. Yet there were still a couple of people who were affected by the stuff and they used it a lot less than others. They now have serious health problems.
Your simily with salt, bears no comparison. Chloride and chlorate may be different, but cyanide and cyanate are not.
Lead used to be used in a lot of things because of it's properties and is a poison. It has been banned because of the health hazard is poses, yet cyanide is more toxic. That is why it has to be used in a controlled environment with the proper precautions.
If spraying at home stick with synthetic or cellulose.
Spyderman
Mark Allanson
posted on 24/9/03 at 07:53 PM Reply With Quote
I'm not a Doctor (trust me!), but we were always told that isocyanate is cumulative. The stuff stays in your body and when your individual tollerance is reached - you die.
Spyderman
posted on 25/9/03 at 04:05 PM Reply With Quote
Originally posted by Syd Bridge
my local paint supplier sells a "Universal" hardener for all 2k paints. So they must all have similar hardeners, no matter whether they are polyester, polyurethane, or acrylic.
I think the universal hardener will be for various different makes of paint, as opposed to different types of paint resin.
Different resins need different hardeners/catalysts to set them off.
Spyderman
Nick Davison
posted on 29/9/03 at 08:01 PM Reply With Quote
I sprayed my nosecone with polyurethane paint, to ensure it didn't stick when I took a mold from it and believe me it is well strong. It fell off the table bounced off a set of metal racking, off the car, off a set of wooden ramps and hit the floor (dented part of the car) and there was no damage to the paint other than a small indentation the size of the end of your finger nail!
And rubbing it down was a real bitch.
By the way I won't use Pollyurethane paint again after reading this thread!
Nick
Nick Davison
posted on 29/9/03 at 08:03 PM Reply With Quote
What is the best way to tackle 1K paint and how much does it cost?
Nick
Mark Allanson
posted on 29/9/03 at 09:23 PM Reply With Quote
Discussed it a little earlier on in this thread, but if you want metallics - used standard polyester basecoat (no gloss - easy to spray) and then 1K lacquer (use straight from the tin - no thinning)
Cheap polyester costs about £18 per litre and 1K clear is about £45 a gallon (i know smaller quantities are available but dont know the cost).
You could also use cob (clear over base) for non metallics is you want. Nice deep gloss and a little more UV stable on reds. The 1K clear will degrade after a few years out in the elements - but should be OK for a car that is garaged most of its life.
stevebubs
posted on 16/4/07 at 06:44 PM Reply With Quote
resurrecting this thread...
I've heard rumours that celly, 2k etc are no longer available. Is this the case?
What are these new "water based" paints that are supposed to replace them?
<<  1    2  >>
