Author: Subject: Overlapping sheets
speedyxjs
posted on 6/11/08 at 09:37 AM Reply With Quote
Overlapping sheets
How can i make a lip in 2mm steel to overlap another sheet?
If no-one knows how to do it with 2mm steel i could (plan B) do it with .8mm ali.
neilj37
posted on 6/11/08 at 09:47 AM Reply With Quote
Can you get your hands on a joggle tool. This would allow you to joggle the one plate and then overlap the other one so that it is flush.
SOmething like the attached pic.
Mr Whippy
posted on 6/11/08 at 09:54 AM Reply With Quote
As above but 2mm seems hard going. Why are you willing to go from 2mm steel to 0.8mm aluminum?! What’s the 2mm for then??
speedyxjs
posted on 6/11/08 at 09:57 AM Reply With Quote
Its for the back panel. I need to secure it round the tranny tunnel. I couldnt make tabs on the panel itself as it wouldnt drop over the the tunnel.
tegwin
posted on 6/11/08 at 09:59 AM Reply With Quote
2mm steel plate for the tranny tunnel
Unless its structural... thats NUTS!... go for .8 ali...(Even thats a little on the thick side IMHO
[Edited on 6/11/08 by tegwin]
www.verticalhorizonsmedia.tv
speedyxjs
posted on 6/11/08 at 10:01 AM Reply With Quote
not for the tunnel, the back panel (behind the seats). I was a bit worried the ali would be too thin for that.
[Edited on 6-11-08 by speedyxjs]
posted on 6/11/08 at 10:17 AM Reply With Quote
I've used 1.2 ally to panel the interior (including rear bulkhead) and TBH it's thicker than necessary. I'd do it with 0.8 or 1.0 next time.
2.0mm steel sheet is bordering on armour plated
posted on 6/11/08 at 10:19 AM Reply With Quote
I used 1.5 or 1.6mm ali - that was more than sufficient, and quite a bit of work!
speedyxjs
posted on 6/11/08 at 10:22 AM Reply With Quote
Ok. Well i now have a (rather thick) template but il make an ali one.
Cheers guys
Mr Whippy
posted on 6/11/08 at 10:49 AM Reply With Quote
as above, steel is simply not needed, far less 2mm. Plastic sheet would be more than sufficient as has been used by some.
Davey D
posted on 6/11/08 at 11:22 AM Reply With Quote
The rear bulkhead on the MNR Vortx is Plastic
neilj37
posted on 6/11/08 at 11:30 AM Reply With Quote
As above, panel on my Vortx is plastic
l0rd
posted on 6/11/08 at 03:32 PM Reply With Quote
Kevlar reinforcement not needed?
