Author: Subject: Best way to attach a tub
bassett
posted on 27/11/08 at 11:23 PM Reply With Quote
Hi, my body does try not to make contact with the chassis so would rivets be strong enough to pull it all in or are bolts better. The reservation i then have about bolts is where ive taped the round tube chassis before i find i only get 1-2 threads which isnt ideal and they often dont end up great. Been thinking bout getting a rivnut gun but heard they can also be troublesome by spinning and the metal is quite thick(chassis 16/18 gauge)or are they ok, so back to the question which methods best or is there an something else?
Adam
vinny1275
posted on 28/11/08 at 08:54 AM Reply With Quote
I've put in rivnuts for mine. caveat - it hasn't been near the road yet! big washers under the bolt head to spread the load tho...
Vince
jabbahutt
posted on 28/11/08 at 10:31 AM Reply With Quote
As above rivnuts with button heads and large washers.
Only done 100 miles to and from SVA but everything seems to be okay, suppose you could always use small thread lock as well?
Nigel
bassett
posted on 28/11/08 at 12:15 PM Reply With Quote
2 votes for rivnuts then, what rivet nut guns you got and where from?
Adam
spud69
posted on 28/11/08 at 03:16 PM Reply With Quote
Adam
Just got delivery of one of these:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=150311147140&ru=http%3A%2F%2Fshop.ebay.co.uk%3A80%2Fitems%2F%3F_nkw%3D150311147140%26_sac at%3D0%26_fromfsb%3D%26_trksid%3Dm270.l1313%26_odkw%3Dmakeendsmeetltd%26_osacat%3D0%26_fvi%3D1
An excellent, robust bit of kit and very easy to use.
