Author: Subject: fitting bodywork
stupott901
Builder
Posts 163
Registered 11/2/08
Member Is Offline
Photo Archive Go!
Building: built mk indy blade now got a cobra
posted on 31/12/08 at 06:40 PM Reply With Quote
fitting bodywork
hi there
just a quick question what the best thing to attach the body panels to the chassis its an mk indy i want to use rivnuts and some sort of screw so i can remove the panels if need be
what type of fixings have people used
afj
posted on 31/12/08 at 06:59 PM Reply With Quote
my rear panel and sides are glued and rivited the rest use m4 m5 m6 s/s button heads
bigpig
posted on 31/12/08 at 07:05 PM Reply With Quote
I used rivnuts and bolts at about 12 to 18 inch intervals. Its a mechanically useful solution if not exactly pretty in the end.
It think reman had the best solution of sikaflex down the side pannels with a couple of rivets at each end.
A1
posted on 31/12/08 at 07:17 PM Reply With Quote
for the sidepanels, i threaded the chassis and put m6 bolts in on the top, underneath i used self tapping screws, for the rear i used rivnuts on homemade brackets...
any panels in particular?
