the moa
| posted on 4/2/04 at 10:47 PM |
will this fit
Just trying to fit my DAX RUSH nosecone and new i had to do soime modifying to make it fir but im not sure its gonna work.
Theres a 20mm gap either side to make it fit flush with the chassis. The idea was to stretch it over the lugs on the Leugo chassis.
Will it stretch ?
Or is it just gonna crack
Anyone got any ideas .
Mark Allanson
| posted on 4/2/04 at 10:57 PM |
I had a similar thing with my westfield one, try warming it with a heat gun, grit your teeth and give it a go! Mine was fine
the moa
| posted on 4/2/04 at 11:32 PM |
Cheers mark will give it go, and hope for the best.
by the way we aint got a heat gun, we ve got hairdryer and blow tourch.!!!! any ideas.
Kitlooney1000
| posted on 5/2/04 at 07:25 PM |
cut the nose cone down the middle and widen it, wont take long.
Simon
| posted on 5/2/04 at 09:38 PM |
Agree with the kitllooney - se pics in my archive.
Will take about two to three hours (if you work har )
Simon
the moa
| posted on 5/2/04 at 10:16 PM |
hi,
i think thats what we might have to do, thanks for the idea.
spoke to luego and they also recommend to cut it.
craig1410
| posted on 5/2/04 at 11:51 PM |
You could try cutting some V's from the flange and that might allow it more freedom to bend to shape.
HTH,
Craig.
the moa
| posted on 8/2/04 at 10:46 PM |
Just bought a westfield bonnet from terry knigtingale whos got lots of westfield stuff going cheap have a look yourself
http://www.terrynightingale.co.uk/parts%20sale.html#anchor106719
and when offering it up into position we have had another idea for the nose cone which we mulling over at the minute, instead of cutting it in half we
could bolt it to the chassis lugs on the outside and then build up the nosecone to make a bulge to cover the chassis rail.
not to sure how easy this would be though !
the moa
| posted on 9/2/04 at 07:58 PM |
I am a bit confused at the minute so to start with are you referring to my question about stretching it so that it fits over the lugs/brackets or
about adding to the nose cone and shaping it so that it has a lip at the bottom to cover my chassis rails ?
the moa
posted on 13/2/04 at 07:40 PM |
It fits now see my phot archive for full pictures
macspeedy
| posted on 13/2/04 at 08:01 PM |
ouch
