aka Keith
| posted on 22/6/09 at 10:12 AM |
wheel fitments
Is vauxhaul 4 stud fitment the same as ford 4 stud?
Will a set of vauxhaul fitting alloys fit onto a ford hub?
philw
| posted on 22/6/09 at 10:14 AM |
No, Ford are 108pcd and VX are 100PCD.
Must try harder
aka Keith
| posted on 22/6/09 at 10:18 AM |
nuts, thanks Phil.
cheers
Craig
philw
| posted on 22/6/09 at 10:27 AM |
nuts, thanks Phil.
cheers
Craig
Yeah, they maybe the same
Must try harder
m8kwr
| posted on 22/6/09 at 10:30 AM |
I believe Peugeot has the same pcd, but depending on the offset you may need a spacer... as most are 15 instead of fords 35
Steve G
| posted on 22/6/09 at 10:49 AM |
There's a guide here that should give you pretty much any alloy fitment. As said the PCD's are different, but the offset is also important
to steering geometry and clearances
linky
mcerd1
| posted on 22/6/09 at 11:29 AM |
also the centre bore is bigger on the pug's (65.1 instead of 63.4) but you can get adapter rings
aka Keith
| posted on 22/6/09 at 11:35 AM |
thanks SteveG, that site is bookmarked.
cheers
Craig
Marcus
| posted on 24/6/09 at 11:39 AM |
Just a quickie, you can't space an ET 15 wheel to ET 35, it's the wrong way. You can do it the other way though.
Marcus
Because kits are for girls!!
