oadamo
| posted on 17/8/09 at 07:05 AM |
moldable foam for body work
anyone no where to get some cheap foam that you can sand into shape so i can fiberglass over to make body panels.
adam
Barronge
| posted on 17/8/09 at 07:13 AM |
I could also do with some
liam.mccaffrey
| posted on 17/8/09 at 07:16 AM |
Will PU expanding foam do? Or will the resin dissolve it.
linky
Build Blog
Build Photo Album
oadamo
| posted on 17/8/09 at 07:21 AM |
has anyone tryed the stuff in cans that you use around windows
adam
balidey
| posted on 17/8/09 at 07:43 AM |
Fibreglass polyester resin gives off 'styrene' which melts any plastic or foam than has a styrene content. So if you use polystyrene foam
then unless you cover it with filler or paint it will melt.
You can use polyurethane (sp) which should not melt, but I would still suggest to cover it with a good coat of paint before applying resin.
balidey
| posted on 17/8/09 at 07:46 AM |
adam
yes, its crap. It doesn't expand at an even rate so you get huge air bubbles in some bits, and its expands rapidly, so you end up spending more
time reworking it.
Best stuff to use is either rigid foam blocks, cut and sanded to shape, or if you are using expanding foam then use the two part foam, only down side
to that is gravity, you need to build it 'up' as otherwise it will just run down. Thats the only plus side to the squirty can foams, its
quick to hold its shape and will almost stick to a vertical face.
[Edited on 17/8/09 by balidey]
Triton
| posted on 17/8/09 at 09:22 AM |
The joys of two part foam, what a giggle that stuff is.....Best way is to make a former or box and pour your two part foam in that then shape it then
glass it...lots of work though
m8kwr
| posted on 17/8/09 at 09:28 AM |
unsure if this link will help
link
wicket
| posted on 17/8/09 at 11:40 AM |
This foam can be used I believe.
http://balsamart.co.uk/store/index.php?main_page=product_info&cPath=104_106&products_id=428&zenid=29f752b9f9add05519ae65411061de15
smart51
| posted on 17/8/09 at 11:54 AM |
Polyurethane foam can come as a 2 part mix or in pre cut sheets.
CFS sell it. It isn't cheap though. I got mine from a local place
in Birmingham and transported it in my inlaw's zafira to save the postage. It is safe to put fibreglass straight on it. I'm making a
whole car from the stuff.
m8kwr
| posted on 17/8/09 at 11:59 AM |
smart51 - do you remember where you got yours from in b'ham - sorry to hijack the post
smart51
| posted on 17/8/09 at 01:50 PM |
I got a lot of my stuff from Polyfibre in Aston. I found them to be good chaps. They talked me out of buying
some expensive stuff and into a cheaper alternative and they've always had what I wanted in stock. They only do office hours though.
oadamo
| posted on 18/8/09 at 12:58 PM |
thanks guys ive ordered some stuff off the net but the amount i need its gonna cost loads.
adam
m8kwr
| posted on 18/8/09 at 01:18 PM |
I'm planning on making a complete body for the car i am designing, and looking at the cost of buying the Polyurethane foam, then the grp
material on top - i nearly fell of my chair.
I think i am going to buy the 2 part Polyurethane and hopefully that will work.... seems to be the locost option
