smart51
| posted on 18/9/09 at 09:37 PM |
paint mask
I've done a bit more paining with my cellulose putty and it is going on nicely. When I'd finished I took my dust mask off and saw that it
was yellow where I'd been breathing through it but still white round the edges. That means it's not just clouds of paint in the air
falling on the mask but the mask actually filtering it out.
So I'm thinking that a dust mask is not enough. What should I be using when spraying cellulose?
R1minimagic
| posted on 18/9/09 at 09:48 PM |
Depends what pore size the mask is....
Mark Allanson
| posted on 18/9/09 at 10:12 PM |
An air fed mask is the only safe way of painting anything, but celly is the most forgiving. If your mask is letting product in via the gaps around
your nose, tape it to your face with masking tape - crude but effective.
NS Dev
| posted on 18/9/09 at 10:19 PM |
agree, once you have used an airfed, you won't want to use anything else.
I used to paint celly at my mum and dad's house in a little single garage and used a charcoal filtered twin filter respirator thingy for that,
seemed to do the trick.
designer
| posted on 18/9/09 at 10:27 PM |
The minimum for sparying any paint is a cartridge mask.
Ben_Copeland
| posted on 19/9/09 at 07:08 AM |
Can you still smell the paint while wearing it? Its a bad sign if you can !
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
smart51
| posted on 19/9/09 at 08:19 AM |
I looked at the mask this morning and it is clean inside which shows that it is filtering paint out. I can still smell the solvent through the mask
so I'm going to look for a cartridge filter.
iank
| posted on 19/9/09 at 09:35 AM |
Machinemart sell them and a range of filters depending what you are spraying or for dust.
http://www.machinemart.co.uk/shop/product/details/tradesman2-twin-respirator/path/masks-respirators
Anonymous
mad-butcher
| posted on 19/9/09 at 10:19 AM |
bit crude but can't think of another way of describing it, if your snot is the same colour as what your spraying your mask ain't working,
air fed deffo I use one of those cheapo compressors outside to feed my mask
tony
blakep82
| posted on 19/9/09 at 11:51 AM |
halfords do some masks that say they're good for paint. its the rubber ones, with 2 filters on the front
i got this kind
you can see how much oragne paint i didn't breathe in when i sprayed my axle with cans
couldn't smell the paint at all when wearing it
[Edited on 19/9/09 by blakep82]
________________________
