myke pocock
| posted on 21/9/09 at 07:19 PM |
Wiper System
Now the car is on the road I have bought the ally extrusions to make the screen frame and I need to look at a wiper system. I know that the early Mini
system can be used but is there another, maybe cheaper, system from the scrappies that I could us? There is a Mini system on the bay at pres but its
up for near on £100 inc carriage. Hardly Locost!!!
Had a brain storming session on names for the car at work the other day. Decided on SID for no real reason at all then got home and it came to me.
SID, Seven Inspired Device so Sid it is, that now lives with Baldrick the trials Skoda Estelle and Sophie the JC Midge. SOFT SOD!!!
| posted on 21/9/09 at 07:41 PM |
May be possible to use something like a Nove/Corsa, Golf, Polo wiper system with a bit of work . The Lucas wiper system is easy to use and reliable.
SVC may be able to supply a kit of all new parts for not a lot more than the one on ebay ?
Canada EH!
| posted on 21/9/09 at 07:49 PM |
Almost anything made by BLMC will have that wiper motor. Lucas unit with metal sleeve containing a spiral wire.
| posted on 21/9/09 at 07:58 PM |
I found that the prices on ebay were ridiculous for complete mini wiper assemblies - not unusual to see a clean example go for £75 - £80, which is
daft when you consider that SVC will sell you a brand-new kit for not a huge amount more (around £140, I believe).
I was lucky - I saw an advert for a 'Mini wiper motor', with a picture showing the whole mechanism. I won the auction - and a complete
assembly arrived!
graememk
| posted on 21/9/09 at 08:28 PM |
Heres an idea, thinking out fo the box a little.
ebay clicky lincky button
Thinking about it
| posted on 21/9/09 at 08:33 PM |
I saw a Tuk Tuk parked up the other day and was looking at the wiper system. It had a short wiper blade with a very small electric motor directly
behind it. I thought two of those may do the trick when the time comes for me. Anyone know a place for Tuk Tuk spares?
mad4x4
| posted on 22/9/09 at 05:58 AM |
Find a landrover breaker and get on for a dedender or old series(II or III) motor
Should get the whole lot for about £20
turbodisplay
| posted on 22/9/09 at 07:06 AM |
Citoen ax makes a good system.
It is a single system, using rod ends i made the unit drive a twin blade setup.
Beauty of an ax system is that it has a smooth system, less wear due to at each end of the flow snapping back.
Darren
scudderfish
| posted on 22/9/09 at 07:07 AM |
How would you ensure they stay in sync with each other?
Daddylonglegs
| posted on 22/9/09 at 09:01 AM |
Kuala Lumpur?
kj
| posted on 22/9/09 at 09:18 AM |
Myke, u2u sent
Think about it, think about it again and then do it.
Marcus
| posted on 22/9/09 at 11:29 AM |
I can confirm that a Corsa/ Nova system works well as long as your under dash wiring is tidy. There are metal bits flailing around under there!
Marcus
Because kits are for girls!!
graememk
| posted on 22/9/09 at 03:54 PM |
the same way as they do on the donor car
