Poll: 3mm strip of RHS? - Poll [View Results]
3/4
3/4 MikeCapon
3/4 MikeCapon speedyxjs
3/4 MikeCapon speedyxjs 55ant
3/4 MikeCapon speedyxjs 55ant rallyingden
3/4 MikeCapon speedyxjs 55ant rallyingden RichardK
3/4 MikeCapon speedyxjs 55ant rallyingden RichardK dave-69isit
Author: Subject: 3mm strip of RHS? - Poll
speedyxjs
posted on 29/10/09 at 02:20 PM Reply With Quote
Im still thinking about my new front end
Im not sure whether to buy some 3mm strip to for the basic structure or use some of my leftover 3/4" RHS.
The RHS woudl be heavier but would mean i could hide the rivets on the inside and it would obviously be stronger.
The 3mm strip would be easier to bend and be lighter but all the rivets would be on show and would not be as strong.
speedyxjs
posted on 29/10/09 at 02:27 PM Reply With Quote
Here is a s**t picture of what i intend to do (will probably look nothing like it when its done )
speedyxjs
posted on 29/10/09 at 02:53 PM Reply With Quote
Not sure whats happened to the poll but the bottom one should be 3mm steel
Benzine
posted on 29/10/09 at 03:03 PM Reply With Quote
Not sure but hope this helps:
speedyxjs
posted on 29/10/09 at 03:05 PM Reply With Quote
^^^ lol Thats made my day
turbodisplay
posted on 29/10/09 at 03:11 PM Reply With Quote
I would say rhs, as the strip will flex, i had soo much flex ihad to reinforce it.
Originally i had about 8 points secured by 50 * 3mm strip and it just wobbled!
I used pu foam behind the outer skin, to make the fibre glass section stronger, then overlaid fibre glass to make the sturcture stiff. Worked well!
Darren
maartenromijn
posted on 29/10/09 at 07:33 PM Reply With Quote
With such a huge front end I would opt for RHS because it will give you a more rigid construction (like turbodisplay-darren says)
BLOG: http://thunderroad-super7.blogspot.com/
Benzine
posted on 29/10/09 at 07:37 PM Reply With Quote
just realised i've used rhs to hold some of my bodywork, it's surprising how heavy big bits of fibreglass can be
Volvorsport
posted on 29/10/09 at 07:54 PM Reply With Quote
hmm slyva strikerish .
www.dbsmotorsport.co.uk
getting dirty under a bus
