Author: Subject: Need a full Waxoil
peterparsons
posted on 17/11/09 at 01:47 PM Reply With Quote
Need a full Waxoil
Any suggestions where I can get a car waxoiled?
I'm in Southampton, so somewhere local would be good.
Mr Whippy
posted on 17/11/09 at 02:01 PM Reply With Quote
I do this myself, but its the job from hell
TimC
posted on 17/11/09 at 02:16 PM Reply With Quote
Likewise in South Wales/Bristol/Herefordshire/Gloucestershire please!
Mr Whippy
posted on 17/11/09 at 02:23 PM Reply With Quote
type - Waxoyl service, into google and a few companys show up
speedyxjs
posted on 17/11/09 at 02:29 PM Reply With Quote
Excuse my ignorance, but isnt it just a case of painting it on?
Mr Whippy
posted on 17/11/09 at 02:35 PM Reply With Quote
True but doing the underside is tough going with a brush unless you can turn the car upsides down. I did the whole underside of the bluebird which took weeks and had me and the garage floor covered in the stuff crawling around on my back, believe me it was no fun at all
Can't find it on the search just now, but there was a thread a while back with a hilarious tale of some guy waxoyling his car in the garage. IIRC he was heating the stuff to soften it for spraying and ended up covered in the stuff with a fire kicking off and total mayhem through out the house as he tried to deal with the situation
Found it....well worth a read for some giggles!
http://www.locostbuilders.co.uk/viewthread.php?tid=79497
[Edited on 17/11/09 by nick205]
speedyxjs
posted on 17/11/09 at 02:50 PM Reply With Quote
I remember that thread. Dont think iv ever laughed so hard
chrsgrain
posted on 17/11/09 at 05:28 PM Reply With Quote
I've heard good things about these guys on the classic car grapevine, but they are in Rugby, so not very local I'm afraid...
Chris
MikeR
posted on 17/11/09 at 07:16 PM Reply With Quote
Used to waxoil a mini with my dad
Made sure it was a nice dry day and had been dry for a couple of days.
Lifted a man hole cover, dad climbed in with brushes and face mask. I pushed the car backwards and forwards over him. He cleaned / brushed under the car.
He got out and had a break, i cleaned up. Sorted out the waxoil and repeated the process of him in the drain but this time spraying.
Once done, took of the wheels and did the arches.
Usually done in a day easily - but my dad does work like a man posessed.
hillbillyracer
posted on 17/11/09 at 07:39 PM Reply With Quote
You need to make sure you know what you want, that whoever does it knows what you want & that they actually DO what you want!
How much do you want to prevent the rust & on what kind of car?
If it's a "normal" car brushing or spraying it on all the underside metal is only touching the surface of doing a good job, rust starts from in all the joints & seams in the bodywork, rarely from the middle of panels unless they've been damaged. This means to really do some good you need to get inside all the body cavities, door trims off, blanking plugs pulled out etc & get in with a long flexi probe that sprays it all over the inside of these sections so it can creep into the seams where the problem really starts.
Obviously if you're paying someone to do it then it's going to get expensive with the labour & as said it's a horrible job so not many will want it.
Question whether it's worth it on most modern stuff, take a wander round a scrapyard these days & not many cars will be in with serious rust problems
I used over 10 litres to do my VW van!
