thunderace
| posted on 8/12/09 at 09:09 PM |
ho do you make a plastic nudge bar
ok i dont want a metal one kid killers ect i (just what it for cosmetic reasons) but would like to make one from a plastic tube the only problen i can
see is bending the it without it collapsing i was thinking of useing boiling water abd a tube bender but not sure if it would work or not,,
i dont knoe if im on to somthing here or not or is it just another mad idear of mine,,,
has anyone bent plastic tube befor i have tryed it with 40mm plumbing tube and it just melted
i would love some advice im sure someone will know how to do it on this forum..
somthing like this
Miks15
| posted on 8/12/09 at 09:13 PM |
mabye use a spring inside or fill with sand? i think the biggest problem will be the plastic pipe collapsing or losing its roundness, and i believe
both of the above are used to stop this, dont know how well it would work with plastic but worth a go mabye?
blakep82
| posted on 8/12/09 at 09:15 PM |
looks like a roll bar to me. you def don't want a plastic one of them.
any pics of this bar on a car?
sand and a heat gun (not blow torch) perhaps?
[Edited on 8/12/09 by blakep82]
________________________
prelude1980
| posted on 8/12/09 at 09:23 PM |
i don't think you'll have much luck forming the pipe to that shape, but you can get plastic bends and pipe that will give a seamless
joint. I work at a plastic fabrication company and we use it for chemical pipework,
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
thunderace
| posted on 8/12/09 at 09:38 PM |
this is what i want to make in plastic tube
[Edited on 8/12/09 by thunderace]
prelude1980
| posted on 8/12/09 at 09:48 PM |
if you don't mind painting it after we can make that at work, here is a link for some plastic fittings we can weld to pipe etc if you look at
the multibend 90 that shows what it looks like, if you like when i go into work i can work out a quick price to do it and with some sizes i can do a
cad drawing to see if it suits you
http://www.ips-plastics.com/downloads/2009Downloads/ppSpigotFusionFitt.pdf
gets you.
thunderace
| posted on 8/12/09 at 10:40 PM |
i would like to try it myself tbh but once i have spent £100 then 6 weeks work and loads of plastic pipe i will give you a shout lol...
morcus
| posted on 8/12/09 at 11:56 PM |
It you want one purely to protect the car, I would have thought you'd be best to have a solid core wrapped in something deformable and attached
with springs of some kind. I looked at a mini that had something like described above so I'd guess some one makes them.
If it's purely aesthetic, you vould just get fairly thick walled plastic tubing and use a solvent to bond them, then grind/build up the join and
cover with paint.
speedyxjs
| posted on 9/12/09 at 09:22 AM |
How about making it from a couple of springs and a straight pipe?
MK9R
| posted on 9/12/09 at 10:22 AM |
Hey, i want to do exactly the same for the front and rear of my Ducato, purely for cosmetic purposes. Check out my bog for the locost racetruck
[Edited on 9/12/09 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
| posted on 9/12/09 at 10:25 AM |
Any chance of getting us 6 x elongated 90 degs, 2 x 90 degs, 2 x Tee 90deg and a few lengths of pipe??
Cheers Austen
RGB car number 9
www.trackace.co.uk
jabbahutt
| posted on 9/12/09 at 10:33 AM |
I can't see any of the proposed photos and I'm really curious what is trying to be built.
Can anyone assist with a photo.
Nigel
MK9R
| posted on 9/12/09 at 10:34 AM |
Nigel
a Bull bar for the front of a van
Cheers Austen
RGB car number 9
www.trackace.co.uk
jabbahutt
| posted on 9/12/09 at 10:48 AM |
ah, many thanks.
mad-butcher
| posted on 9/12/09 at 03:55 PM |
Seems like a good way of wasting money, spend money making nudge bar someone backs into it breaks your nudge bar they get away without a mark
you're out of pocket. Bollocks you hit my pajero's nudge bar you need a new rear end, now you won't do that again will you.
tony
thunderace
| posted on 9/12/09 at 10:46 PM |
tony
dont worrry a new mk6 transit bumper is only around £30
