Bluemoon
| posted on 31/1/10 at 05:24 PM |
Side screen hinges
Hi all,
I am looking for some stainless steel (or crome ect) lift of hinges for side-screens. I have some Caterham plastic ones but they look far to weak to
hold my 1m long lexan/ali ones I want to build.
I have in mind something like these CBS ones
linky, but being tight they are far to
expensive!
Any ideas of other suppliers?
Dan
[Edited on 31/1/10 by Bluemoon]
| posted on 31/1/10 at 05:27 PM |
The Caterham ones are okay- I used them on my side screens. Only problem is that my screens are light and so the screens ride up on the hinges and
evently come off!! Not the best. I ended up using some engineering grade string to hold them down.
Sounds like gravity will do this for your with your heavier screens!
jambojeef
| posted on 31/1/10 at 10:04 PM |
Ditto.
Mine are long lexan and ali jobbies and the Caterham hinges are fine - I milled some ally blocks for the rear of the side screens to rest on when
closed though but no worries so far.
Geoff
prawnabie
| posted on 31/1/10 at 10:05 PM |
Europa spares - they were about £8 odd for the set when I bought some last year!
prawnabie
| posted on 31/1/10 at 10:07 PM |
https://www.europaspares.com/BRIGHTWORK/HINGES_and_LATCHES/BRIGHT_LIFT_OFF_SIDE_SCREEN_HINGES___BLOSH__1828.html
zetec
| posted on 31/1/10 at 10:09 PM |
I,ve got Dax ones which are metal and will be well up to the job.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
GeoffT
| posted on 1/2/10 at 09:32 AM |
There's some stainless one's here:-
Link
....5358 look like suitable jobbies. Can't work out how you get the price though, maybe a phonecall is in order..
Bluemoon
| posted on 1/2/10 at 11:23 AM |
Thanks prawnabie, had a look at them but are they really galvanized? That would look nasty when the get old and oxidized, or are the actually zinc
plated?
Might give the catervan ones a go first from the sounds of it, but add rest at the back to take the strain off as jambojee.
GeoffT good find, 5358's look the business, I check them out.
[Edited on 1/2/10 by Bluemoon]
prawnabie
| posted on 6/2/10 at 12:11 PM |
Ive had mine of for 2/12 years now and no signs of corrosion!
