matty h
| posted on 3/2/10 at 04:31 PM |
caterham windscreen
Will a caterham windscreen assembly fit a MK Indy
whitestu
| posted on 3/2/10 at 04:46 PM |
I've got one on mine:
There are a couple more pics in my photo archive.
Stu
iscmatt
| posted on 3/2/10 at 04:56 PM |
Stu,
do you know if the glass will fit in an MK made surround? Quite fancy a heated screen over demisters but i think i would be incredibly lucky if it
did!!!
Bluemoon
| posted on 3/2/10 at 04:57 PM |
quote: Originally posted by iscmatt
Stu,
did!!!
I doubt it! You'd be better fitting the whole screen (and that will not fit perfect, and also not work with MK's weather gear).
Dan
Marcus
| posted on 3/2/10 at 04:59 PM |
I got one too, but mounted on top of the top of the bulge as it gave more room for the wiper mechanism
Marcus
Because kits are for girls!!
Marcus
I got one too, but mounted on top of the bulge as it gave more room for the wiper mechanism
Marcus
whitestu
| posted on 3/2/10 at 05:04 PM |
Stu, do you know if the glass will fit in an MK made surround? Quite fancy a heated screen over demisters but i think i would be incredibly lucky if
it did!!!
I don't know but wouldn't think so. The glass in mine was cut at a local place and isn't heated.
That's a good suggestion!
I thought of doing that, but only after I had fitted it and cut all the holes!
Stu
iscmatt
| posted on 3/2/10 at 05:19 PM |
yeah, i didn't think it would but you never know!! I think i'll just get me-self a demister come MOT time
whitestu
| posted on 3/2/10 at 05:26 PM |
If it's just for the MOT don't bother as it isn't tested.
Mine went though fine.
Stu
matty h
| posted on 3/2/10 at 05:59 PM |
If you have a full screen what do you need for a MOT, do you need a demister and wipers.
mangogrooveworkshop
| posted on 3/2/10 at 07:17 PM |
Stu,
did!!!
Two totally different shapes.....guaranteed
whitestu
| posted on 3/2/10 at 09:02 PM |
Wipers [that auto park] and washers are all you need.
Stu
iscmatt
| posted on 3/2/10 at 10:57 PM |
Stu
I did wonder whetherto chance it without, i'm sure someone on here said that it is a requirement for MOT. Have to try with out i think as it
would be a bit of nightmare trying to fit them under the scuttle!
