James
| posted on 27/4/10 at 03:30 PM |
Re-mounting rear wings- rivnuts or nuts & bolts
Further to my moaning post last week about jobs to do on the car, one of them is to raise the rear wings by 1" so they're flush with the
rollbar mount and hopefully will no longer hit the tyres on full bump.
First time around I used a mixture of rivnuts in the side panel and nuts/bolts in the boot area. No real idea why I did it this way.
Only problem now is I don't have a rivnut tool!
I can probably borrow one from someone but wondered if I need to.
So, any effective ways of doing it from others? Any benefits of nuts/bolt versus rivnuts?
I spose rivnuts are good as I won't have to remove the inner panels/boot panel to remove the rear wings!
James
[Edited on 27/4/10 by James]
- Muhammad Ali
sucksqueezebangblow
| posted on 27/4/10 at 03:56 PM |
I'm probably going to use ally nuts and bolts 'cos I don't like rivnuts, they have a tendency to spin and then you have to make a
mess of the panel to get them out.
Alan M
| posted on 27/4/10 at 04:41 PM |
I agree with above
I used 4 stainless nuts, bolts and penny washers for each wing and have had no problems
Humbug
| posted on 27/4/10 at 04:52 PM |
I used nuts and bolts with penny washers when I had to change my wings. No probs.
spdpug98
| posted on 27/4/10 at 04:56 PM |
I used nylon nuts and bolts with metal penny washers, I believe some of the racers do it in the hope that if they get a tap then the bolts break
rather than the wing/body
My Blog: http://spdpug98.wordpress.com/
| posted on 27/4/10 at 05:08 PM |
Nice idea re the nylon bolt shearing. Should also snap off if some plonker decides to try sitting on your car!!
Neville Jones
| posted on 27/4/10 at 05:42 PM |
Was having this same conversation with a friend just last weekend. Final conclusion was to use Dzus quarter turn fasteners.
Makes it quick and easy to get the wings off to do any work on the rear corners when needed.
Nev.
lsdweb
| posted on 27/4/10 at 08:26 PM |
As spdpug98 said - nylon bolts / nuts especially if you're going to "track" it.
Wyn
Steve Hignett
| posted on 27/4/10 at 09:15 PM |
Rivnuts aren't really best used for something like that.
What you need are Jack Nuts...
RK
| posted on 28/4/10 at 01:16 AM |
I vote for bolts and penny washers. Rivnuts are a real pain in the bum - although you don't need a tool, two nuts (one oversize) and a wrench
will do. I've even used nylon picture hangers with steel screws into my car in some places.
James
| posted on 28/4/10 at 01:35 PM |
Okay, thanks all!
James
- Muhammad Ali
