chris666
| posted on 25/6/10 at 04:55 PM |
cycle wings
Anyone know where i can buy some metal strips that the cycle wings bolt onto?and any idea of what size/grade.
The cycle wings are from carbon modz.
Chris
| posted on 25/6/10 at 05:25 PM |
My set-up uses 5mm steel bar... It's not exactly light but it's not going to break. I would have thought B+Q would be able to supply it
(if you need it quick and don't mind the wallet abuse).....
speedyxjs
| posted on 25/6/10 at 06:58 PM |
I got some 5mm bar from b&q the other day to make mine. cost about £3 for 1m
Gordy
| posted on 25/6/10 at 07:12 PM |
I bought csr style cycle wings from carbon mods about a year ago, not sure what grade they are but they can match them to your wheel/tyre size so you
can get a nice tight fit around tyre
chris666
| posted on 26/6/10 at 07:25 AM |
cycle wings
whats the best method of attaching the cycle wings to the wing brackets?
Dont fancy drilling holes in my nice shiny carbon!
big-vee-twin
| posted on 26/6/10 at 08:00 AM |
You can use adhesive like Sikaflex, form a piece of aluminium sheet to the profile of the inside of your wing, securely bolt it to the stays and then
apply glue to your wing along its length to stick to the ali
http://www.triangleltd.com
chris666
| posted on 27/6/10 at 10:03 AM |
cycle wings
has anyone got a picture of the wings bolted to the stays,just want an idea of how they go before i drill in the wrong place.
Chris
| posted on 27/6/10 at 10:10 AM |
Sikaflex didn't work with my Carbonmods wings as I found out at (around) the legal limit on the A14. Survived with just a scratch. They are now
bolted on with some fairing bolts. Front wing bolts from a late 3 series BMW look neat, they may do the job nicely
