Author: Subject: Trim_4_Wheel Arch Curves.
Dick Axtell
posted on 7/10/10 at 02:19 PM Reply With Quote
Just to explain what I'm on about, here's a pic :-
Wheel_Arch_member
Wheel_Arch_member
What do most peeps use to cover these curved members? And where can it be obtained?
I recall ST builders were able to use rear wheel covers to fit over the accompanying chassis. However, this is an old MK chassis.
Has any body used beaten/moulded ally sheet in this area?
bbwales
posted on 7/10/10 at 02:22 PM Reply With Quote
I used item 84 from here http://www.blackburnsmetals.com/products-aluminium-mouldings-cope.html did the all tops of the cockpit in it.
Regards
Bob
posted on 7/10/10 at 03:03 PM Reply With Quote
I used ally carpet edge trim from B&Q - gives a nice radiused edge and is easily bent to follow the curve. Started by rivetting the bottom in place then bent/formed and riveted around the chasis rail.
Dick Axtell
posted on 8/10/10 at 08:59 AM Reply With Quote
Thanks both. Will call in at B&Q - its near my lock-up.
