Author: Subject: getting a decent grip with a rubber lined p clip
jabbahutt
posted on 17/11/10 at 11:05 AM Reply With Quote
Morning all
Trying out another daft idea last night which for once may actually work. My problem is I'm trying to secure a reasonably light weight item to a 20mm diameter tube. I'm trying to use a 19mm rubber line p clip though even when tightened fully it'll still easily slide round the tube.
Is there anything I can apply to the p clip or tube to make it grip much better?
Any ideas much appreciated as normal
minitici
posted on 17/11/10 at 11:21 AM Reply With Quote
Sikaflex
jabbahutt
posted on 17/11/10 at 11:33 AM Reply With Quote
Sorry should of mentioned that it would be handy to have the sub assembly easily removeable hence using a p clip, which rules out sikaflex.
Thanks though.
RazMan
posted on 17/11/10 at 11:53 AM Reply With Quote
How about the stuff that is used to make fan belts more grippy?
Raz
minitici
posted on 17/11/10 at 11:55 AM Reply With Quote
Wrap some ptfe tape or apply a release agent before using Sikaflex on the P clip.
You should then be able to remove the P cilip once the Sikaflex has cured.
Thinking about it
posted on 17/11/10 at 01:20 PM Reply With Quote
Grub screw
martyn_16v
posted on 17/11/10 at 04:07 PM Reply With Quote
Wrap some electrical tape around the tube before you put the p-clip on, to make the tube dia a bit bigger
twybrow
posted on 17/11/10 at 06:11 PM Reply With Quote
This gets my vote too... I find self amalgamating tape is ideal, as it is slightly sticky/grippy to the touch.
posted on 17/11/10 at 08:33 PM Reply With Quote
What are you actually trying to secure? Can you use a pair of jubilee clips and small brackets?
