aaron-wxm
| posted on 17/1/11 at 09:54 PM |
fuel & brake lines
not sure which section to post this
but where can fuel & brake lines pass from the rear of the car to the brake cilinder & fuel rail (iva friendly please )
pics would be great
thanks alot
daniel mason
| posted on 17/1/11 at 10:01 PM |
along the bottom of the transmission tunnel under propshaft is generally the way! clipped roughly 200mm apart.
aaron-wxm
| posted on 17/1/11 at 10:16 PM |
cheers mate i wasnt too sure if they were alowed in the same tunnel as the prop
i was thinking of making a little tunnel above the prop and pop them in there?
or just simply in the same tunnel?
thanks
big-vee-twin
http://www.triangleltd.com
stevegough
| posted on 17/1/11 at 10:50 PM |
You can run everything down the tunnel, but electrics and fuel have to be run seperately. P-clipping is essential, for everything - for IVA there is
a mandatory spacing of 300mm for electrics. However, you will fail if brake lines rub against ANYTHING which could chafe. There is quite a few guys
on here who will advise you NOT to use rubber fuel lines in the tunnel (and one or two who say they've used rubber ones but never had one leak.
Personally, I fitted rubber ones, then, after weighing up the arguments (and before it was too late) I changed over to the 8mm copper ones. As far as
brake lines are concerned - you are best with the 'proper' brake line clips(see link at bottom of this post) - (I had already p-clipped mine
before I heard about these).
Before...rubber fuel lines.
After.....copper ones fitted.
Brake clips
[Edited on 17/1/11 by stevegough]
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
aaron-wxm
| posted on 18/1/11 at 04:00 PM |
thanks alot for the pictures really appreciated and alot of help
aaron
