The Venom Project
| posted on 23/2/11 at 01:23 PM |
Painting the letter on wheels
I have just sourced some wheels with the name embossed into the rim, so I want to highlight this, has anyone actually been this sad and done it?
What technique did you use?
I know how messy I will be with a brush, so was thinking to use a syringe and drop the paint into the lettering.
What has anyone else done?
Nick
It's not that i'm lazy, it's that I just don't care.....
loggyboy
| posted on 23/2/11 at 01:26 PM |
Either Brush it in over the top, or mask thebasic area and spray it on, then just t-cut the excess off when its touch dry.
blakep82
| posted on 23/2/11 at 01:30 PM |
you can buy motorbike tyre marking pens in halfords, like a little pen filled with paint, you can just colour in the bits you want. only white or
yellow though i think
________________________
The Venom Project
| posted on 23/2/11 at 01:38 PM |
Painting wheels
Cheers, might try the spray then, have a green tyre pen, but its too fat for the detail I need.
MakeEverything
| posted on 23/2/11 at 02:14 PM |
Try a touch up pen for paint. They use a fine "Syringe" type end whereby you should be able to squirt the paint into the required area.
Kindest Regards,
Richard.
Agriv8
| posted on 23/2/11 at 02:39 PM |
used these to mark controll race tyres who they are rotation corner ect.
Edding 750 White Paint Pen Marker 2 - 4mm
regards agriv8
swanny
| posted on 23/2/11 at 02:46 PM |
this may be a stoopid idea.... i have ed em before but could you wipe a cloth impregnated with sillicone across the face of the wheel then spray the
whole area?
i thought the paint applied to the siliconed areas would just wipe off?
MakeEverything
| posted on 23/2/11 at 04:40 PM |
whole area?
Id use grease. Paint reacts with silicone, hence the "Fisheye" effect in some panels.
Kindest Regards,
Richard.
mistergrumpy
| posted on 23/2/11 at 11:23 PM |
You can get paint pens in a small nib sizes and loads of different colours from hobby shops. They're used for ceramic or glass painting.
loggyboy
| posted on 2/3/11 at 10:37 PM |
Decieded to do my VIN today as it was showing signs of rust and wanted to make it clearer.
One engraved VIN:
Mask and spray a couple or 3 coats
(Vert) lightly sand with some Wet and Dry (1200 grade IIRC, lots of water, only over letters and avoided edges of chassis and welds)
Finish off with some cutting paste (Tcut was fine for this)
Schimples.
The Venom Project
| posted on 6/3/11 at 11:36 AM |
They arrived in white
The went to Powder Coat and came out Satin Black
I then used a syringe to drop the paint into the lettering, it worked very well and I have made matching centre caps
