smart51
| posted on 25/5/11 at 01:15 PM |
body filler without hardner
Oops! I've done a silly thing. I sprayed on some spray filler without mixing in the hardner. It has "set" to something like
putty. I'm going to scrape it off and do it again properly. Do I need to get every trace of it off or will the hardner in the next layer cure
any remaining traces in pin holes etc?
tegwin
| posted on 25/5/11 at 02:15 PM |
I have done this before... Just make the next layer a bit stronger with more hardner... get it applied quickly so it doesnt set, and it should then
cure the rest of the filler
www.verticalhorizonsmedia.tv
deltron63
| posted on 25/5/11 at 06:51 PM |
If i was you i'd take it all off. You wouldn't build a house on dodgy foundations.
It's pain, but you might as well get it right now
