| posted on 26/10/11 at 03:25 PM |
Body Filler --- looking for one that isn't too "draggy"
years since I bought body filler but doing a Tintop repair on sill nasty bash which I have pulled out as much as I can and filled with filler. I
used both Metallised U-Pol and P38 filler and have the profile right and just need a final skim of filler. I have found the U-Pol very draggy
and P38 must have changed because it was no better I can't find the old stand by Plastic Padding "Elastic" locally so any
recommendations ?
r1_pete
| posted on 26/10/11 at 04:00 PM |
I've been using Upol D metallic on the Jag instead of lead loading - cos I can't do it.
Very smooth application, clog free standing providing it is fully set, and strong, I trapped the seatbelt buckle in the door after I'd evened
the gap and it didn't chip.
You'l probably need to find a decent factor who stocks it, I paid £16 for 1.1 kg.
designer
| posted on 26/10/11 at 04:10 PM |
I think we used to put acetone onto the spreader to stop it dragging.
Also, we used a plastic bag to push it on when we wanted a thin coat.
imp paul
| posted on 26/10/11 at 04:17 PM |
dolphin glaze is used in insurance work its like smooth
r1_pete
| posted on 26/10/11 at 04:21 PM |
I'm going to have to try that Dolphin Glaze for the final finishing, got to be more economical than coat after coat of primer filler...
| posted on 26/10/11 at 05:32 PM |
I use stopper for the last coat when I need it but usually get away with a thin skim of Upol easy sand, the Smooth 7 stuff.
| posted on 26/10/11 at 05:40 PM |
Interesting I will google it, trouble is the neighbours would report me to the conservation police if they saw me taking a large marine mammal
out the boot :-)
StrikerChris
| posted on 26/10/11 at 06:01 PM |
Just chuck abit of fibreglass resin in whatever you've got,I've never had no problems,makes it loads easier and workable for longer.
Fred W B
| posted on 26/10/11 at 07:37 PM |
I"m also impressed by Dolphin Glaze, see
post here
Fred W B
[Edited on 26/10/11 by Fred W B]
twybrow
| posted on 27/10/11 at 07:58 AM |
The body filler from Screwfix is fanatstic - very easily applied, and no dragging.
imp paul
| posted on 27/10/11 at 08:08 AM |
haha go easy with the dolphin lads we don't want no neighbour bashing lol
[Edited on 27/10/11 by imp paul]
