RK
| posted on 18/11/11 at 03:20 AM |
removing wings from stays
Bonded on with silicon, with one bolt on each wing. How difficult is it to remove a carbon wing from a stay? I will need to bend the stay again for a
different diameter wheel.
Need to go larger diameter wheels for road clearance (have 15" wheels). 13" just don't leave enough room to do speed bumps and our
crap surfaces without risk of major damage.
Ivan
| posted on 18/11/11 at 07:00 AM |
Why not just raise the ride height?
big_wasa
| posted on 18/11/11 at 08:50 AM |
Pu is very strong.
Take the bolts out and use a very thin wire (cheese wire) to slice between wing and stay.
As for re bending the stays then I wouldnt do that ! These things crack in half for fun.
I am swaping wheels and have bought new arches and will make new wing stays aswell.
Mine arnt carbon
Bluemoon
| posted on 18/11/11 at 10:05 AM |
Have to agree re-bending cold, but it is possible if you heat them up cheery red and work them whilst hot.
Also are you sure you want 15" can't you go for a higher profile 13" tire?
owelly
| posted on 18/11/11 at 10:50 AM |
I also recommend cheery red. It really makes them happy....
http://www.ppcmag.co.uk
NigeEss
| posted on 18/11/11 at 11:29 AM |
The wire that the likes of Autoglass use for removing windscreens is
perfect for this task.
RK
| posted on 18/11/11 at 05:38 PM |
sounds exceedingly dangerous. how would I change the ride height? New dampers/springs again?
all suggestions are welcome though! thanks!
[Edited on 18/11/11 by RK]
big_wasa
| posted on 18/11/11 at 05:57 PM |
Your wings are the bit you need to save with out damage (carbon £££). I would remake the stays. I am re making my stays this week end. Ive found new
wings for £15. new steel, same again.
If you up the profile of the tyres you will need to do the stays anyway.
I doubt there will be the travell in the shocks to adjust the height you want.
I am changing to 15's for the higher speed rating for iva. Dia is the same but they are 1/2" wider.
| posted on 18/11/11 at 08:28 PM |
Windscreen removing wire works
RK
| posted on 19/11/11 at 06:53 PM |
Sounds too risky for me. How much are new stays for MX5 hubs do you think? Might be easier to go to a machine shop locally and have them reproduce
them there.
