Author: Subject: Sanding block help.
jossey
posted on 6/12/11 at 06:23 PM Reply With Quote
Sanding block help.
Yes I know it's a not random. I need a long sanding block for sanding my body work but they are fetching silly money on the bay etc.
Any ideas on how to make one or get one cheaply.
I used I use a 20" one which was good.
David Johnson
Fred W B
posted on 6/12/11 at 07:16 PM Reply With Quote
I bought a cheap hardware store sanding block, to rob the spring loaded clips off.
Sanded/planed an actual block of wood flat.
Stuck 3 or 6 mm closed cell foam to the block
Screwed the clips on
Done!
Fred W B
posted on 6/12/11 at 08:41 PM Reply With Quote
Never found long boards anywhere, always ended up making up with plywood --- a stiff one and one with a bit of flex for gentle curves.
Mark Allanson
posted on 6/12/11 at 08:48 PM Reply With Quote
Screwfix rolls of sandpaper, homemade longblock complete with handles like a plane, drawing pins to secure - locost heaven!
