Author: Subject: Fabric side panels?
The Shootist
posted on 13/8/04 at 03:47 PM Reply With Quote
Fabric side panels?
I've been looking at "Locost" methods to build the lightest reasonable chassis for a BEC build.
A few years ago I was interested in "Homebuilt" aircraft and heatshink fabric is often used in their construction.
Has anyone considered using Dacron, or Ceconite, glued to the upper and lower rails, and the diagonal/vertical members to take the place of ally side pannels.
The fabric would be glued in place, heatshunk to a "Drumhead" tension, then painted with a "plastisized" finish to fill the pors in the fabric and give a "smooth as glass" appearance.
Cost of the fabric is less than $10 US per yard of 70" width fabric. 3.7 ounces per square yard.
blueshift
posted on 13/8/04 at 03:55 PM Reply With Quote
I know nothing about this stuff but wouldn't it be rather fragile? prone to holes from stones, clod-footed passengers, etc?
The Shootist
posted on 13/8/04 at 04:04 PM Reply With Quote
Pretty strong actually...
Dacron and Ceconite have tensil strengths of 70 and 130 psi respectively.
mangogrooveworkshop
posted on 13/8/04 at 05:05 PM Reply With Quote
10 out of 10 for the mans thinkings
dblissett
posted on 13/8/04 at 08:54 PM Reply With Quote
nice idea
nice idea my only concern would be at the front just before the botom whisbones the alli pannels dont fit flush with the chassis the panell sticks off the bottom rails by a couple of inches if you can get round this problem you could be on to somthing
good luck dave
Jon Ison
posted on 13/8/04 at 09:03 PM Reply With Quote
i like the idea too, will follow with interest.
posted on 13/8/04 at 09:22 PM Reply With Quote
i was thinking of wrapping carpet tape around various chassis members to fill holes and save weight (effort really, not weight, but thats just me...)
i think the SVA man wouldnt be impressed by taped panels, but these other things you are on abotu might go down well.
my main argument with myself was that my panels are fully welded at the min, and so add something to the strength too.
heinlein
posted on 13/8/04 at 09:57 PM Reply With Quote
Aircraft coverings
Great idea; I wish I had thought of it.
Back in 2001 I sent for a catalog from Aircraft Spruce & Specialty Co.; it's almost 600 pages and full of interesting stuff. At that time they had a book "How to cover an aircraft using the poly-fiber system" it goes on to descibe it as a whole covering course in a spiral-bound book, 135 pages of clear, non-jargon, step-by-step instruction. P/N 09-06000 $10
They also had a 2 hour VHS video called Aircraft Fabric Covering
P/N 13-40428 $39.95
They also have a Ceconite Procedure Manual.
P/N 09-01000 $5
They also sell several different fabrics including Ceconite in three different weights ranging from 1.7 oz. - 3.7 oz. for from $6.95 - $7.45 per yard in 70 inch width. Dacron comes in 1.8 oz. - 3.7 oz. for $3.10 - $3.80 per yard in 64 - 66 inch widths.
In my opinion the lightest weights are not appropriate for our use based on my interpretation of the descriptions in the catalog.
They also have various coatings and tools.
I have no idea if any of this 2001 info is still valid. Hope at least some of this is useful.
When you're lying in the midst of the Afghan plains and the women come out to cut up the remains; just roll to your rifle and blow out your brains and go to your god like a soldier.
crbrlfrost
posted on 14/8/04 at 12:02 AM Reply With Quote
Sounds like a great idea to me. I've seen it used by UTA in FSAE and they seemed to have great success with it. Don't know how well it would survive gravel, but then again, props can throws rocks all to well too. Cheers!
madforfishing
posted on 14/8/04 at 09:54 AM Reply With Quote
I was thinking the same, Dave.
Maybe it could be done with ali stringers, or similar, between the rails. Although even done like this it's still going to be 'angular' and not curved like the original. Also, I can see that method taking as long as making a full panel fit.
I don't doubt someone on here will come up with a solution.
By the way, what will the fabric covering save on weight, compared to a car skinned in ali ? How easy to remove a damaged panel ?
My Mrs already thinks the car is 'dangerous', as you can 'touch the floor outside!' (hmmm, out of the mouths of babes eh?).
I'm sure she'd love it if a fabric panel was all that was between her and the road she is so desperate to touch. Oh well, I can save on weight by removing the other seat, as she won't be wanting to come along then.
dblissett
posted on 15/8/04 at 06:34 AM Reply With Quote
mrs
if your mrs is anthing like mine she will love the thought of fabric
she must do thats all she spends her/my money on
good point about changing panels i will stick to stainless 0.7mm
dave
locoboy
posted on 8/2/05 at 03:29 PM Reply With Quote
Reignighting an an old one here. Has anyone got any new ideas or takes on this subject?
Im thinking Nylon Ripstop material with a hem at the bottom which an ally flat bar can be threaded and rivited through into the bottom of the lower chassis rail. and for the top im thinking of it folding over the top of the top chassis rail and all the way under the top rail and secured with self adhesive velcro.
Should be able to pull it tight enough for it not to flap about in the wind.
Any thoughts apart from the afore mentioned about cut outs for exhausts, or the structutal properties or riveted or welded side panels etc.
Could prove an interesting concept. All you need is a book pattern making up then choose your colour of nylon ripstop material.
I can feel a harlequin moment coming on!
Locoboy
Dale
posted on 8/2/05 at 04:12 PM Reply With Quote
how about kevlar material- cept it does not come in the nice colours of ripstop nylon.
Dale
locoboy
posted on 8/2/05 at 04:38 PM Reply With Quote
I think the kevlar material would be at a price to turn anyone or anything a shade of any colour you wanted!
We buy Kevlar webbing at work and the 50mm wide stuff is 5.30 per meter!
Locoboy
dblissett
posted on 8/2/05 at 09:19 PM Reply With Quote
nylon
will the nylon ripstop withstand the heat from a exhaust manifold i dont know anything about the stuff its the nylon in the name that makes me ask
cheers dave
locoboy
posted on 9/2/05 at 09:22 AM Reply With Quote
Dont know Dave,
Its something i need to experiment with.
I have a bid in at the moment on some ripstop nylon - hopefilly enough to do to sides
Some self adehesive reflective foil type film could be stuck on the inside of the nylon to act as a heat sheild.
Locoboy
locoboy
posted on 10/2/05 at 09:18 AM Reply With Quote
Looks like i have secured myself some ripstop from e-bay so i can have a go at seeing how it will / wont work
Locoboy
