pauladamss
| posted on 9/12/11 at 10:39 AM |
bodywork
What does everyone use to make holes in the bodywork for the wishbones ect is a dremel the tool for the job or is there something better?
jossey
| posted on 9/12/11 at 10:55 AM |
dremel with the black carbon discs i think they are. they little metal discs didnt work well for me.
David Johnson
deezee
| posted on 9/12/11 at 11:16 AM |
I used masking tape to cover the area. Marked it. Made a series of drill holes, linked them together with a hacksaw blade (with masking tape wrapped
around one end to hold. Then filed it out neat. Worked a treat and saved me spending a fortune on a Dremel.
iank
| posted on 9/12/11 at 11:34 AM |
These are easier/quicker than files, but that's the way I'd basically do it. Wear a mask (grp or ally) when using flap wheels as
there's going to be plenty of dust
Anonymous
wylliezx9r
| posted on 9/12/11 at 12:20 PM |
I used a normal hole cutter, mask the area first, and cut from the gel coat side. Perfect hole and really quick too.
George Best
big-vee-twin
| posted on 9/12/11 at 06:22 PM |
[img]
 (600 x 450).jpg)  (600 x 450).jpg) Side Panel First Cuts
[/img]
http://www.triangleltd.com
Ben_Copeland
| posted on 9/12/11 at 07:49 PM |
Covered in masking tape, used a template to mark the masking tape.
Cut out holes with a hole saw and angry grinder, then used a die grinder to clean up the holes and add the correct shape etc.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
