roohunter
| posted on 18/12/11 at 04:19 PM |
mk rear wings
hi folks
i have bought a part built mk indy and have removed one of the rear wings as it is slightly more forward than the other side,but no matter what
position i put it in ,it is always to close to the tyre at the front bottom edge.
i have re mounted it in exactly the same position as the other side and it is still nearly touching the tyre.
anyone else had this happen?
HELP!!!
what can i do ,can you buy new wings?
thanks folks
wylliezx9r
| posted on 18/12/11 at 04:30 PM |
Is the rear tub fitted square ? Maybe a defective arch, otherwise im stumped.
George Best
Ben_Copeland
| posted on 18/12/11 at 04:32 PM |
Wishbones fitted correctly?
I'd get under the car and start checking why things aren't lining up.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
ReMan
| posted on 18/12/11 at 05:12 PM |
Unfortunatluy I think that there is a slight variance between the L and R mouldings and that it in not unknown to have to adjust to best fit
www.plusnine.co.uk
macc man
| posted on 18/12/11 at 06:39 PM |
I had a similar problem and found that to line the wing up I had to fix one side and bend the arch to fit in correct position. There should be a fair
amount of flex in the wing so it should stretch.
austin man
| posted on 18/12/11 at 06:54 PM |
Its a problem with the mould you can reduce the problem by stretching the wing into place and then securing it will never be 100% though
daniel mason
| posted on 18/12/11 at 07:02 PM |
Has the mould been sorted yet? Or is it just a problem with the older cars?
roohunter
posted on 30/12/11 at 04:13 PM |
success at last
hi folks,
thank you all for your help,just thought i would let you know i got my wing to stretch by submersing it in the bath ,with red hot water and then
bracing it with a piece of timber while it cooled and got 3/4 of an inch movement.
thanks folks
