sdh2903
posted on 13/1/12 at 11:08 AM |
rivets and painting.
Quick question, when fitting ally side panels is it better to paint first then rivet, or rivet then paint? Just wondered if the rivet heads would
cause any issues with paint cracking etc?
mark chandler
| posted on 13/1/12 at 03:56 PM |
I rivited then painted mine, the paint has not cracked around the rivits.
Pay extra attention when sanding around the rivits, then wipe down with thinners.
Paint very quickly after rub down, literally minutes as the ali will start to oxidise in free air, use a decent etch primer, U-Pol acid etch #8 as the
first primer.
If you paint then rivit you will end up having to touch in all the rivits afterwards, not fun.
Regards Mark
[Edited on 13/1/12 by mark chandler]
