Twin40
| posted on 12/3/12 at 08:40 PM |
Nose cone fitting
Hey guys, just a quick one - can someone send me a link or show me a good way of fitting the nose cone properly. I can't work it out!
cheers
daniel mason
| posted on 12/3/12 at 09:06 PM |
do you mean fixing it down or trimming to fit?
as for fixing, i would drill an 8 or 10mm hole in the base at each side,put a strip of decorators tape along the top of the body tub(so you can mark
the hole for drilling) put the nose in position, mark with a pencil through the holes you drilled in the nose, remove the nose,then drill through the
marked hole throug the top part of the body tub and into the top chassis rail. insert a 6mm riv-nut into chassis rail,bolt through with washer on top
side and job done!
rb968
| posted on 12/3/12 at 09:11 PM |
That's how I did it as well plus I added a Ali bracket at the front underside into the bottom rail. Rivnut in there as well.
Rich
daniel mason
| posted on 12/3/12 at 09:29 PM |
i actually did that also! might be a bit less forgiving if i hit a curb though.
40inches
| posted on 12/3/12 at 09:30 PM |
Or you could hinge it so it tips forward
YQUSTA
| posted on 12/3/12 at 09:34 PM |
I would question the use of rivnuts, just because if it ever decides to slip how would you get the nose cone off without a lot of stress.
Why not just drill straight through the chassis rail and use a longer bolt and never have to worry.
That's how mine are.
"If in doubt flat out"
Colin McRae
twybrow
| posted on 12/3/12 at 11:28 PM |
You risk crushing the tube if you just drill it and bolt. Plus with a rivnut, you only drill one of the 4 faces of the tube, so you could debate it
retains more strength... Plus, my tiny rivnuts weigh less than your longer bolt!
MkIndy7
| posted on 12/3/12 at 11:44 PM |
Or just tap the chassis rail, more than strong enough and the lightest and easiest option of the lo!!
Twin40
| posted on 13/3/12 at 07:48 AM |
Thanks gents, much appreciated!
mad-butcher
| posted on 13/3/12 at 07:59 AM |
make sure you use serated rivnuts,
tony
YQUSTA
| posted on 13/3/12 at 08:19 AM |
Good point well made mate, though I don't think I posses the strength to do that :-)
I would go with MkIndy7's idea after reviewing all the options if I were doing it.
Colin McRae
loggyboy
| posted on 13/3/12 at 09:27 AM |
You would be suprised how easy it is when your applying the magnified force that a nut/bolt does!
A1
| posted on 17/3/12 at 02:54 AM |
I went for tapping the chassis rail, with a strip of ali to spread the load. have seen a hinged one too, its a good idea
| posted on 17/3/12 at 09:01 AM |
I welded two tabs on the chassis and bolted through the lip of the nosecone where the bonnet ledges on with a roofing bolt, the heads are pretty low
so they don't cause a problem and the bonnet hides them and one at the middle front bottom rail with a rivnut.
[Edited on 17/3/12 by Peteff]
