Author: Subject: U trim on front wings
pekwah1
posted on 30/1/13 at 09:57 PM Reply With Quote
Hi Guys,
So i really have tried searching but as the search isn't really working it's difficult....
Anyway,
What adhesive is best suited for gluing rubber U trim to my fibreglass/gel coat bodywork?
austin man
posted on 30/1/13 at 10:09 PM Reply With Quote
Once knocked on it grips really well I didnt glue mine
MsD
posted on 30/1/13 at 10:14 PM Reply With Quote
We tried allsorts of 'proven' methods when we did ours. Found out that superglue worked best for us.
Mark
macc man
posted on 30/1/13 at 10:22 PM Reply With Quote
I used superglue on all my rubber trims. If you use the metal reinforced trim you should not need any glue.
austin man
posted on 30/1/13 at 10:24 PM Reply With Quote
I used the metal reinforced type
deezee
Mine, which has the metal reinforcement, is still on the car and its been more than a year on the road now.
ReMan
posted on 30/1/13 at 10:39 PM Reply With Quote
+1 Fitted for SVA and still on 6 years later
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Daddylonglegs
posted on 31/1/13 at 07:23 AM Reply With Quote
+2, not moved a jot since fitting, once on and 'secured' with a gently tap from a rubber mallet it is on for the longhaul
steve m
posted on 31/1/13 at 09:36 AM Reply With Quote
I thought most of this trim fell off after IVA ?
wicket
posted on 31/1/13 at 11:43 AM Reply With Quote
Channel section rubber about 10mm wide fixed with superglue, been on for 7 years and no problem. Personally I think it looks neater that the metal reinforced type.
snapper
posted on 31/1/13 at 01:25 PM Reply With Quote
I used 6mm rubber U trim glued on with superglue
Silicon or PU works ok but PU can be messy
I eat to survive
I drink to forget
