Sloan85
| posted on 1/9/13 at 04:09 PM |
What polish for GRP?
I covered my car in polythene when I trailered it the other week as heavy rain was forecast. This was a mistake as the polythene has blown about in
the wind and dulled areas on every panel. What is the best polish for bring the gel coat back to a gloss finish? I have some Autoglym Super Resin
Polish fomr when I was into detailing my Civic Type R but not sure whether these products designed for paint can be used on gel coat.
What about waxing the GRP. Any product recommendations?
http://mkindygsxr.blogspot.co.uk
jacko
| posted on 1/9/13 at 04:31 PM |
Autoglym is what i use
Sloan85
| posted on 1/9/13 at 04:44 PM |
cheers, ill give that a go.
jacko
| posted on 1/9/13 at 04:57 PM |
read my roll bar sticker
Volvorsport
| posted on 1/9/13 at 05:03 PM |
Farecla g3 then mould release wax
www.dbsmotorsport.co.uk
getting dirty under a bus
twybrow
| posted on 1/9/13 at 05:12 PM |
Another vote for Forecla products - they are the industry standard for gelcoat finishing.
doobrychat
| posted on 1/9/13 at 05:32 PM |
G3 is Gods cream in my eyes.. blooming excellent stuff but beware of immitations on Farecla products...
jacko
| posted on 1/9/13 at 06:01 PM |
I bet that stings
Xtreme Kermit
| posted on 1/9/13 at 06:43 PM |
Autoglym Super Resin Polish on my shelf.
Sloan85
| posted on 1/9/13 at 07:12 PM |
Had a go with the Autoglym SRP but it isn't shifting the marks. Is there a more abrasive polish or do I need to have a go with a rotary
polisher?
ashg
| posted on 1/9/13 at 08:05 PM |
farcella g3 with an electric mop and plenty of water its the only way.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mark chandler
My vote is for meguiars compounding polish, be careful with a rotary you may burn the surface unless you know what you are doing.
plentywahalla
| posted on 1/9/13 at 08:53 PM |
Polyester gel coat is very different from paint in that it suffers from oxidisation and chalking caused by Ultra Violet radiation. Ordinary waxes such
as beeswax or carnuba will give a good shine but their UV protection will last only about 50 hours when exposed to sunlight.
You need a polish with long term UV barrier protection which usually means ones containing Silicones. The problem with Silicones is that they are
highly mobile and can migrate into the gel coat itself. This leads to adhesion problems when the gel coat is subsequently repaired or refinished, it
can also lead to embrittlement over the longer term. We always recommend that Gelcoats are polished with Polishes containing PTFE which has long term
UV protection without the problems associated with Silicones.
Note that polish manufacturers sometimes use trademarks for PTFE such as Teflon and PTEF in their descriptions.
Rules are for the guidance of wise men ... and the obedience of fools. (anon)
Sloan85
| posted on 1/9/13 at 09:23 PM |
Excellent information! Thanks for that.
Can you suggest any products? Cheaper the better at the minute!
plentywahalla
| posted on 1/9/13 at 09:38 PM |
Look here
Linky
Richard
[Edited on 1/9/13 by plentywahalla]
theduck
| posted on 2/9/13 at 06:24 AM |
Forgive me if i am wrong, but are polishes not meant for correcting paint and sealants and waxes for protection?
Slimy38
| posted on 2/9/13 at 08:10 AM |
I believe that is correct, polishes by definition are effectively abrasives (albeit incredibly fine abrasives), whereas waxes just lie on top. If the
OP has dull panels then I believe a polish is the best product, at least initially.
It has always made me cringe when people say that they polish their car every weekend, it should not be necessary. A wax every weekend might be ok
(although still overkill), but polish is removing clearcoat/paint.
plentywahalla
| posted on 2/9/13 at 08:24 AM |
I think you are identifying the difference between compounds and polishes.
Reality is most of the compounds sold for use on paint attempt to do both and contain waxes and silicones for protection as well as the abrasives for
cutting back the surface. They are in effect a one step process.
I was trying to answer the OP's question and highlight the difference between paint and gelcoat, and that a product designed for one was not
ideal for the other.
I usually find the best results are obtained on gelcoat by using a separate abrasive compound and then a pure polish.
Mozzie
| posted on 14/9/13 at 03:07 PM |
Are you doing it by hand or do you have access to a Rotary or DA?
By hand then the SRP will do, but you will have to use elbow grease to get the results.
I wouldn't use G3 without going to G10 after, the G3 WILL leave micro marring due to its "cut".
I use menzerna on GRP (2 stage) followed with a wax. (Thats using a DA by the way).
I always read the blurb about PTFE in products and wonder how they get it to bond to the paint/grp without the heat that is needed to get it to bond.
