nick-york
| posted on 1/11/13 at 10:27 PM |
sealant ???
Hi ! Is sikaflex the best sealant for putting between aluminium and the chassis before i put the rivets in ?cheers. Hope I've spelt it right !
big-vee-twin
| posted on 1/11/13 at 10:53 PM |
Yes or you can use tiger seal.
http://www.triangleltd.com
unijacko67
| posted on 1/11/13 at 10:57 PM |
I used a good quality clear silicone and its worked great.
http://www.kittenkitcar.co.uk
| posted on 2/11/13 at 06:51 AM |
I think there are various types and grades of sikaflex but yes, it's good stuff.
FuryRebuild
| posted on 2/11/13 at 09:19 AM |
I'd steer away from the adhesive side of sikaflex. It's tougher than no more nails. There may be a time when you need to remount your
body. It will come off in pieces if you've used adhesive.
Clear silicone as mentioned above is a good plan.
www.furyrebuild.co.uk
onenastyviper
| posted on 2/11/13 at 10:07 AM |
aren't the panels bonded to provide more structural strength?
"If I knew what I was doing then it wouldn't be called research would it?...duh!"
adithorp
| posted on 2/11/13 at 10:24 AM |
If you want the sealant to be structural then use a PU (polyurethane) sealant, Sykaflex, Tigerseal, etc. Remember though, if it's sticking
panels to chassis, it's only as strong as the bond between your paint/powder-coat and the steel. It will make removal very difficult though.
If you just want it to seal the panel to keep moisture out then use a silicone sealant.
http://jpsc.org.uk/forum/
Mark Allanson
| posted on 2/11/13 at 10:52 AM |
DON'T use silicone, it's solvent is acetic acid which will eat your ally and rust your chassis in very short order
iank
| posted on 2/11/13 at 10:57 AM |
+1 use builders sealant if you don't want adhesive not sanitary. The neutral cure is also stronger than acetoxy cure iirc.
http://www.screwfix.com/p/no-nonsense-builders-silicone-clear-310ml/83710
Anonymous
40inches
| posted on 2/11/13 at 10:58 AM |
The best Silicon for just sealing is Silicon P, this is an inert sealer used for Polycarbonate roofing panels.
adithorp
| posted on 2/11/13 at 11:30 AM |
What do you call "short order"? I've just had a removable ally panel off that I'd sealed with silicone 6-7 years ago. When I
peeled the sealant off it was still shiney underneath.
