phelpsa
| posted on 2/1/05 at 11:37 PM |
Scuttle
When I bought my car it came an ali scuttle which has wood in the back. Is this needed?
Adam
Mark Allanson
| posted on 3/1/05 at 12:06 AM |
Commonly known as a dashboard?
phelpsa
| posted on 3/1/05 at 12:09 AM |
AT THE BACK!!
The engine end of the scuttle, but inside.
Adam
robinbastd
| posted on 3/1/05 at 12:13 AM |
I'll have the wood for the llama cremation.
http://smuttygifts.com/
Mark Allanson
| posted on 3/1/05 at 12:20 AM |
Whoever built it must have thought it was necessary, perhaps used as a former to retain the shape whilst the scuttle was skinned
Talking of skinned, why waste a dead llama?
robinbastd
| posted on 3/1/05 at 12:23 AM |
I'll get the next one delivered to you. Home or work sir?
phelpsa
| posted on 3/1/05 at 12:28 AM |
Okay, so it's ok to remove it.
Adam
jack trolley
| posted on 3/1/05 at 08:30 PM |
The wood would (!) be extra support if you were going to attach anything to the
engine side of the scuttle; i.e. fuseboxes or other electrical bits.
dblissett
| posted on 5/1/05 at 09:14 PM |
wood
its fine to remove it
i think wood is sugested as a former in rons book but you must have something between the engine bay and the cockpit
fiberglass or ally normally
cheers dave
krlthms
| posted on 8/1/05 at 08:15 AM |
If you look at the pictures of preparing a locost for racing in the Champion book, they have the scuttle sitting on two parallel round steel tubes
that are welded to the chassis, but this mod is not mentioned in the text.
So, you may want to take the wood off and replace it with two steel tubes that look like mini-roll bars.
KT
