albertz
| posted on 9/1/05 at 08:22 PM |
Fuel filler cap/hose
I have just bought a filler cap from Think Auto and tried to fit it yesterday, only to find that the filler neck on my tank (taken from my donor
Corolla) is 43mm OD and the OD of the filler cap is 52mm. Does anyone have any suggestions as to how this can be sorted?
I am under the impression that the hose normally used is specially for fuel and therefore dont want to just make something fit that is lying around
i.e. water hose.
I have emailed Think Auto for their advice/recommendations, but thought i would ask here as well, as there may well be a cheaper alternative, which i
have overlooked.
As always, any help appreciated.
Stu16v
| posted on 9/1/05 at 10:51 PM |
I had a similar problem. I just bought some suitable fuel hose to suit the smaller ID (from Europa IIRC), and it stretched fairly easily onto the
larger ID fuel cap.
HTH Stu.
| posted on 9/1/05 at 11:32 PM |
maybe 'big it up' with a few layers of duck tape, then jubilee it tight!
mookaloid
| posted on 10/1/05 at 10:17 AM |
I think I would be a little concerned about using duck tape for a fuel filler application.
Doesn't petrol dissolve the adhesive on the tape?
Mark
DarrenW
| posted on 11/1/05 at 10:51 AM |
Yes it does. I would be more tempted to get some 43ID / 52OD tube, put this onto tank first then fit filler pipe. (ie make an adaptor).
Of course that size pipe is going to be nigh on impossible to get but 40ID (or similar) will stretch etc etc. Might be an idea though.
We have a local motor factors (very big one) that can do bespoke fuel pipes etc. They get them from a place called Linden Hose in Newton Aycliffe (Co.
Durham) who can also make hydraulic pipes, up to the sizes used on commercial vehicles and JCB's. I dare bet most large places will have a
supplier similar for pipe and tubes etc.
Another idea - can the tankl filler neck be modified? What about making an ali or stainless tube bent to desired angle and fitted with flexi pipe at
each end (if space allows).
IHTH
Darren.
albertz
| posted on 11/1/05 at 01:10 PM |
Thanks for the suggestions. I think the best way would be to scrap the original filler neck and make a new one the correct OD, or at least turn out a
sleeve to slide over the existing filler and put a weld around it to seal it. In fact that is what i will do. Turn a sleeve with an ID of 43mm and an
OD of 52mm.
Still need a cheap supplier of 52mm hose, approximately 6" long
Thanks again.
BTW if anyone has any alternative solutions please let me know as i wont get to the lathe until the weekend at the earliest.
Mark Allanson
| posted on 11/1/05 at 09:00 PM |
If anyone does find a reasonable supplier, I need about 3" of 50mm ID Fuel Hose.
Rorty
| posted on 12/1/05 at 03:45 AM |
What about making a reducer? Any exhaust shop will have an exhaust shrinker/expander with which they could alter a short length of tube to suit the
difference between the hose and filler neck.
You may even find a similar expansion on the end of an existing unused exhaust pipe.
Cheers, Rorty.
