joneh
| posted on 4/1/18 at 12:34 PM |
Finishing GRP after a cut
I'm fitting a roll bar to my Fury, but I'll need to cut the rear tub down, as I have an early one with 3 point belt mounts, so the rear
tub almost touches the back of the seats. When I cut it, I'll be removing the radius fold at the edge.
How should I finish the cut? Simple U channel, or should I make another folded lip in GRP (or stick the cut off piece back on, less a few inches) as
I guess this part also adds strength?
Thanks,
Jon
Mr Whippy
| posted on 4/1/18 at 12:42 PM |
pictures would probably help tbh
joneh
| posted on 4/1/18 at 12:44 PM |
Sure will add some when I get home.
jossey
| posted on 4/1/18 at 02:49 PM |
I have sprayed up the edge after cutting which seems good but not easy to do but easiest and most popular will be the knock on edge stuff.
David Johnson
joneh
| posted on 4/1/18 at 04:55 PM |
Image below hopefully. I need to trim the lip off and about 15cm.
jossey
| posted on 4/1/18 at 08:03 PM |
Knock on edge trim then. Defo.
David Johnson
1960dave
| posted on 5/2/18 at 06:12 PM |
I was once told by a laminator to use super glue on the raw edges.
joneh
| posted on 5/2/18 at 06:32 PM |
Sounds like a plan to stop the fraying. Will use a trim to make it look nice. Cut came out ok using my multi tool.
[Edited on 5/2/18 by joneh]
