Author: Subject: Fuel filler hose
ger
posted on 5/2/05 at 11:08 PM Reply With Quote
Fuel filler hose
Hi all,
Any cheap sources for this???
Need about 500mm of the flexi stuff.
Ger
stephen_gusterson
posted on 6/2/05 at 12:05 AM Reply With Quote
europa spares do it, but its not cheap - about a pound an inch if i remember - so you need 20 quids worth!
atb
steve
bob
posted on 6/2/05 at 12:15 AM Reply With Quote
Or
http://www.thinkauto.com
posted on 6/2/05 at 01:09 PM Reply With Quote
I used ThinkAuto - this stuff is always expensive, but they're the cheapest.
ger
posted on 6/2/05 at 07:41 PM Reply With Quote
fuel filler pipe
cheers folks...! Knew of these guys but thought it was expensive for some rubber tube! But I guess thats what it costs....
I've lot count of the money I've spent on the little bits....bolts, fibreglass, drills, rivets etc etc the list goes on and the cost spirals up and up!!
Wheres te best place to buy stainless fasteners..
Gerry
stephen_gusterson
posted on 6/2/05 at 10:52 PM Reply With Quote
look in your yellow pages. there is likely to be a place somewhere in your area that sells nuts and bolts . my local one will sell any small qty i need.
atb
steve
posted on 6/2/05 at 11:56 PM Reply With Quote
There is always I.F.S. they are quite popular... but our's has a minimum charge of £10. Unless you know them well...
ger
posted on 7/2/05 at 09:44 AM Reply With Quote
I.F.S. ???
Who are they?
Ger
irvined
posted on 3/3/05 at 12:02 AM Reply With Quote
I got mine from demon-tweeks, im sure you can get it cheaper, but its ultra flexible, (basically a big spring with some plastic around it.)
It was £13 for 300mm, it did the bend between tank and filler with no problem.
D
Jeffers_S13
posted on 30/6/05 at 08:36 AM Reply With Quote
D
What sort of bend ridius are we talking here ? My approximate dims between filler and tank are 6" across then 7" down. I just got some 'flexible' 57mm ID hose from Merlin for the bargain price of £26 plus VAT that is next to no use, its flexible in that its not rigid...ho hum. I could get a steel bend and use this stuff as joiner hose but Im a bit annoyed this is no good.
