Author: Subject: Clear over Base spraying
ady8077
posted on 15/3/05 at 05:08 PM Reply With Quote
Hi all
I've bought some colour base coat with a 1K clear coat, I got all the info on mixing etc, but I'm a bit unsure how to spray it. Are there any good web sites that show the best technique. All i can find on google is celly
Adrian
Mark Allanson
posted on 15/3/05 at 07:00 PM Reply With Quote
What do you need to know?, mix the basecoat 2:1 with MS thinners, allow to flash off and cover with the clear (1 light plus 2 full coats)
ady8077
posted on 15/3/05 at 07:47 PM Reply With Quote
Hi Mark
I wasn't sure if you had to rub down between coats, or how long you have to wait between coats
The chap at the paint shop was really helpfull but they were busy, and i've forgot half he said
Adrian
Mark Allanson
posted on 15/3/05 at 08:14 PM Reply With Quote
Definately DON'T rub down between coats. Apply the basecoat with 2 medium coats (3 if silver or a pale colour) followed by a drop coat (gun at about 600mm away from the job to accentuate the metallic elements - if metallic!).
There is a critical recoat time, too soon and the paint will pickle up, and too late and the clear will peel later. Usually this is about 15-40 mins, but check with the paint suppliers as manufacturers vary.
ady8077
posted on 16/3/05 at 06:54 PM Reply With Quote
Thanks Mark
Its begining to sink in
Adrian
Mark Allanson
posted on 16/3/05 at 06:57 PM Reply With Quote
Any time, if you get stuck, just drop me a line
