jambojeef
| posted on 6/6/05 at 12:50 PM |
Wheel Arches too narrow?
Hello,
Took delivery of my luego rear arches last week - tried them on last night and my wheels seem to poke out wider than the arch by about 20mm at least.
Im using their widest fitment - 280mm and book width chassis - sierra track - 205 tyres - 35mm offest (phew).
Has anyone else some across a similar problem - the wheels DO have be inside the arches for SVA dont they?
Geoff
Mix
| posted on 6/6/05 at 12:58 PM |
That's the problem using Sierra width back end in a book chassis, the wheels stick out further and consequently you need wider rear arches.
I've modelled mine in CAD and will be looking for arches in the region of 310mm wide, I've been told by others on here that they are
available
Mick
jambojeef
| posted on 6/6/05 at 01:15 PM |
Odd though cos the locost that luego do runs the sierra back end (or so I thought) and so should be ok...?
Hmm - will have to measure up when I get home and make sure that they have sent me the right 280mm ones and not the 215mm by mistake
Geoff
Liam
| posted on 6/6/05 at 02:02 PM |
Oh man they dont fit!!!??
Actually the luego locost is just a book live axle car. the luego velocity is their sierra one and thats the arches I've got. they are
11.5" wide which is.... 292mm. So maybe still pushin it a bit with your phat dubs. It's ok on mine cos my chassis has an extra inch.
Ah just get some chrome wheelarch extensions for the sva!!
Aiight
[Edited on 6/6/05 by Liam]
jambojeef
| posted on 7/6/05 at 08:32 AM |
Yeah - will probably do that I think - get some extensions on for SVA or somehting - dunno man!
Geoff
DarrenW
| posted on 9/6/05 at 08:01 AM |
For info ive just measured my Mac#1 rear arches - 295mm from body side to outside edge of arch.
jambojeef
| posted on 13/6/05 at 11:00 PM |
Ok think I might have a plan on this one....
your comments please......!
I have totally measured up and it aint as bad as I thought it was - only maybe 15mm outside the arch (!).
I reckon - turn a load of ally spacers up at about 15mm and use a length of scorpio door seal to bridge the gap.
Might not be the prettiest but after SVA I can always just take the spacers off and run with pokey outy wheels??!!
What say you?
Geoff
Mix
| posted on 14/6/05 at 06:11 AM |
Or a piece of MDF profiled to match the wheel arch.
Mick
