Avoneer
| posted on 26/6/05 at 05:22 PM |
Lolocost nose cone fitting
Anyone any tips on where to start with a Lolocost nose cone?
Shall I line up the bottom edge with the centre of the lower front suspension brackets and keep "hinging" it back from there until the
flange the bonnet will sit on is parallel to the top chassis rail?
Pat...
| posted on 26/6/05 at 07:19 PM |
is the bonnet on yet? Try balancing it on a pile of books to get it to the right height, and see where the lower edge ends up.
On mine, the radiator sits on a small bar at the front, i hinged mine onto this and it all worked well. except for the bonnet, obviously...
Avoneer
| posted on 26/6/05 at 08:27 PM |
Not doing bonnet yet.
Was going to do nose and then fit the MK scuttle and build the bonnet around those two.
All the pics I see in Uncle Rons book have the lower edge of the nose cone in line with the bolts for the bottom front wishbone brackets.
Might be easie to sort a hinge out now and then chop the upper edges of the cone of accordingly until it sits on the top chassis rails.
Pat...
niceperson709
| posted on 26/6/05 at 10:31 PM |
Hi Pat
i have only seen pictures of the nose cone you mention but two things come to mind , firstlya s youa re building a BEC , the amount clearance you
need between your engine and the bonnet should help you work out the hight of the nose cone . and I tend to think that a gap between the bottom of the
nose cone and the chassis looks really tacky IMHO. So perhaps you should fit your scuttle first andd then you can adjust your nose cone so it sits as
low as possible and still gives you a bonnet line that clears the engine . I thought about hinging the nose cone on mine but in the end thought that
it was unnecessary complication, because how often to you really need to acess the stuff in there? ( I plan a filler for the cooling system at the
rear of the engine bay )
Best wishes
Iain
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
chrisf
| posted on 27/6/05 at 12:47 AM |
Hey Pat:
I agree with Ian: Fit the scuttle first, then the bonnet, then the nose. If you're making a bonnet from ali, you could fit the nose before the
bonnet.
The thing is, the scuttle has a very particular place. If your nose cose is a 1/4" too far forward, who cares? If the scuttle is 1/4" off,
you'll see it immediately.
--Hope this helps, Chris
