Author: Subject: McSorley 7+4 Chassis
davepro
posted on 18/7/05 at 05:43 AM Reply With Quote
This is a book chassis but 100mm longer and 100mm wider.
Does any one know of a supplier of body panels i.e. nose cone, bonnet and rear panel.
I was looking that the Luego Vinto but I'm not sure on the dim of the chassis.
Thanks in advance.
Dave Prouten
nludkin
posted on 18/7/05 at 07:51 AM Reply With Quote
Darren at GTS I believe can supply bodywork for the +4 McSorley plans. His new W7DE kit is the same dimensions I believe.
http://www.s123613988.websitehome.co.uk/w7de_body.htm
craig1410
posted on 18/7/05 at 11:53 AM Reply With Quote
The McSorley 7+4" is only 4" wider, not longer. It is the same length and height as a book chassis.
As said above, Darren at GTS Tuning should be able to help you out.
Craig.
James
posted on 20/7/05 at 01:15 PM Reply With Quote
Nosecone and scuttle could definately come from Darren (the scuttle mould was finished last week I'm led to believe!). I'm not sure how they do their back panel though so best to ask Darren about that.
I think you'll need to make your own bonnet though unless they can do you a one-off.
HTH,
James
