Author: Subject: harness "triangles"
smart51
posted on 5/9/05 at 12:59 PM Reply With Quote
harness "triangles"
I fitted one of my harnesses last night and looking at the triangle piece that bolts to the chassis, it doesn't seem to be radiused at 2.5mm. Do I need to trim the edges for SVA?
posted on 5/9/05 at 01:05 PM Reply With Quote
I took some small-diameter PVC tube (about 5mm o.d.), slit it along one side and pushed it over the edge of the bracket. The free ends were tucked under the belt and the whole thing secured with some strong button thread.
It look neat and 'permanent', but I can't take any pictures to show you what I mean as strangely it fell off shortly after the SVA test...
shortie
posted on 5/9/05 at 01:46 PM Reply With Quote
I just put some of the same herringbone u-trim I used for the fibreglass seat edges on them and it was fine.
HTH,
Rich.
posted on 5/9/05 at 01:57 PM Reply With Quote
Aren't harnesses e-marked?
If so does that not deem them as OK?
Nick
mookaloid
posted on 5/9/05 at 02:11 PM Reply With Quote
They need to be protected for SVA
The markings just mean that they comply with the strength standards or summat not that they will pass an SVA test from a 2.5mm radius point of view
HTH
I just did it as 'over-kill' - to reduce the chances of the SVA man finding anything.
The e-mark relates to strength, buckles, etc. The safety of the fixing bracket edges is dependent upon where they are fastened - whether they can be got by the tester's sphere or not. On my car, they can be got by the sphere.
posted on 5/9/05 at 04:10 PM Reply With Quote
We missed that one... but we got a pass anyway! Strange how some things are overlooked isn't it?
