mad4x4
| posted on 21/9/05 at 04:25 PM |
Cycle wings
By design do the edges of these meet SVA or do I have to try and stick edging all around it?
I bought some rubber edgeing for mini arches by with keeps coming off. Can I not bother.
Do the rear wings need edging round the wheel edge?
Scot's do it better in Kilts.
RoadkillUK
| posted on 21/9/05 at 05:24 PM |
On mine I found the fronts need it but the rears didn't, stuck it on with superglue and I personally thing it makes is look neater too,
it's still on 1 year after passing SVA
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
DarrenW
| posted on 22/9/05 at 08:02 AM |
i had some trim supplied with my Kit that was called 'concept trim'. It is only a small u section but has a bead of glue inside.
Apparently it is hard to get hold of now so if anyone knows a potential supplier id be interested.
if the trim and arch is warmed up before fitting it sticks nice and solid. Unfortunately i dont have enough so am keeping my eyes open for some
more.
Do the cycle wings have to be trimmed right round?
Dave J
| posted on 22/9/05 at 01:14 PM |
I'm with lee on this one. The rubber edging certainly finishes mine off nicely.
I would certainly edge them all round as it would look rather strange having all but the inboard edge trimmed.
I suspect the SVA inspector would expect all the edges to be fitted with the beading.
I have super glued mine on the inside edge to avoid getting any surplus on the outside face of the GRP.
Be warned, I accidentally got a bit of super glue on the grp and finished up frantically wet and drying the area followed by a manic polishing (it
eats into the surface of the GRP). Ok now though.
Dave
jonbeedle
| posted on 26/9/05 at 11:07 PM |
Use the herringbone pvc edge trim from www.woolies.co.uk
It's less than £2/meter and has a metal insert which stops it coming off. I used it and so have loads of others. It looks good too!
Jon
[Edited on 26/9/05 by jonbeedle]
"Everyone is entitled to an opinion however stupid!"
indykid
| posted on 26/9/05 at 11:10 PM |
get it from m&m trim supplies. it's only £1.50 a metre, and is far more flexible than stuff other people supply.
tom
