Author: Subject: 3mm 5 bar Aluminium Checker Plate
jimgiblett
posted on 4/11/05 at 05:12 PM Reply With Quote
Where the cheapest place. Ideally in the South or cheap delivery. I need four 62"x14.25" sheets.
TIA
Jim
[Edited on 4/11/05 by jimgiblett]
Humbug
posted on 4/11/05 at 05:36 PM Reply With Quote
Not sure how ar it is for you, but I got some offcuts from Spa Aluminium in Tunbridge Wells - might be worth a call to find out their prices, anyway
Spa Aluminium Ltd
Unit 1 Chapman Way
Tunbridge Wells TN2 3EG
Tel: +44 (0) 1892 533911
Fax: +44 (0) 1892 533911
Email: sales@spaaluminium.co.uk
mark chandler
posted on 4/11/05 at 07:14 PM Reply With Quote
Don't bother phoning, as it will cost you more (start involving the office).
Call in at the goods inwards shutter doors and push the button and ask for some scrap ali (I think the chaps name is Bob) and they will call someone across.
Its tread plate, not chequer plate and the price will be based upon weight, the scrap value.
There are usually a few 8 x 4 whole sheets with scuffed edges and a huge guillotine so measure up what you want and get it cut to size !
Regards Mark
Humbug
posted on 4/11/05 at 07:51 PM Reply With Quote
yes - I should have said that. They weigh it. If you've got the real measurements you need you will hopefully be able to find bits to fit
jimgiblett
posted on 7/11/05 at 09:42 AM Reply With Quote
Thanks Humbug and Mark I'll give them a try.
Jim
ChrisGamlin
posted on 11/11/05 at 09:13 PM Reply With Quote
Jim
Depending on price if it helps the deal I might be interested in some to re-panel the centre of the trailer I use. Could even use the trailer to get it all back maybe
Chris
